Thank you very much for sending the firmware update. I hope the problem with turning off after grid disconnects will be solved.
There is one more question. What is the algorithm for turning on the AC, if the station was completely discharged (before this, the station operated in UPS mode and AC was turned on), after that grid connects, the station turned on for charging, but the AC mode did not turn on immediately. Will it turn on automatically when the station reaches 5% charge? Right? Or will it have to be turned on manually through the application?
Hi @Vaksa , These two firmware versions are essentially the same, version 04 is pushed individually, while version 03 is pushed in batches. You can choose either one for the upgrade.
I have the same problem- Bluetti completely shuts down when electricity goes off. I have to turn it on manually and then all works fine. Pls push this new firmware for me too
AC180P2335001484052
Arm: v2089.03
Dsp: v2088.03
Bms: v1039.01
Splendid!
Hope to see the fan issue resolved in the next batch so we won’t have to micromanage it under <100 watts loads.
I couldn’t recommend this product to my friends and relatives when they asked because of this firmware nuances since most of us use it as a UPS with laptops and fiber internet. Not to mention, fans on max speed drain power.
I have the same fan issue on both of my AC180P stations as VSM and design have.
Whenever something with low power consumption (say less than 100W) is being powered by the station, after a while, the fans start spinning as if the station was being charged in Turbo mode. Once you add more power consumption (be it 500 or 1000W) fans start spinning normally. I would assume this is a bug rather than a feature. Kindly assist.
Thank you.
1. SN: AC180P2335002001026
ARM: v2089.03
DSP: 2088.04
BMS: 1039.01
2. SN: AC180P2341000252355
ARM: v2089.03
DSP: 2088.04
BMS: 1039.01
By the way, thank you for fixing the issue with the UPS mode with the 2088.04 update! Cheers!
Hello, @BLUETTI
I have updated ARM of AC180P to v.03
Possibility of turning display off/on when display timeout is set to Never is a convenient feature.
Thank you.
I already see in the Forums that this update will get pushed in waves for everyone. So there is no need to write down you Serial Number anymore. Keep an eye of the update page. It should reach you too.
Please, send me a new firmware.
AC180P2352001540791
ARM v2089.03
DSP v2088.02
BMS v1039.01
UPS mode doesn’t work, as soon as the light goes out, the station turns off and needs to be turned on again
Hi @Kate, please log into the Bluetti app, can you find the new DSP v2088.03? Please upgrade the firmware to resolve this problem. Please do not load any device when upgrading it.
