Hi @BLUETTI_CARE ! Thank you for getting back on this! I would be happy to try out the new firmware but I still haven’t received the one.
Duplicating the S/N just in case: AC180P2349002235901
Still have no updates here :( really need it asap
@BLUETTI_CARE
AC180P2335001073432
ARM - v2089.02
DSP - v2088.02
BMS - v1039.01
Hi @BLUETTI_CARE,
Same issue here. Could you please push this fw to my device as well?
AC180P2332001474436
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hi, @BLUETTI_CARE,
24 hours ago I sent a request for an firmware update, but have not received it yet. Perhaps I wrote it in the wrong place, so I’m duplicating it here.
My Bluetti AC180P works as UPS for fridge.
Serial number is AC180P2349000040459
arm v2089.02
dsp v2088.02
bms v1039.01
My Bluetti AC180P is randomly turns off when the grid disconnects in UPS mode. Please push the new firmware to my Bluetti.
Regards,
Andrii
Hello, could you be so kind to provide me with a new firmware too.
AC180P2341000198851
ARM v2089,02
DSP v2088,02
BMS v1039,01
Thanks in advance.
Hi! Same issue here. Could you please push this fw to my device as well?
AC180P2335001646247
ARM 2089.02
DSP 2088.02
BMS 1039.01
Thanks!
Please send me an update go version 2088.04
AC180P2344000717181
ARM v2089,.02
DSP v2088.02
BMS v1039.01
Hi! @BLUETTI_CARE
I have the same problem. Please, send me a new firmware to fix it.
AC180P2349001576941
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please, help me to fix this issue.
AC180P2349001761850
ARM 2089.02
DSP 2088.02
BMS 1039.01
Thanks!
Hello!
New Bluetti AC180P works as UPS for fridge (Serial number is 2344004195326, 2344004331017, arm v2089.02, dsp v2088.02).
Today, my Bluetti shutdown after grid disconnected. Charge level was 100%. Please send me a firmware update.
Regards,
Eugeniy
Hi @BLUETTI_CARE !
Please update my power station.
AC180P2344004023990
ARM version v2089.02
DSP version v2088.02
BMS version v1039.01
Hello, I have the same issue.
SN: AC180P2344000658732
ARM v2089.02
DSP v2088.02
BMS v1039.01
Could you please sent the new firmware to my device ?
I have the same problem. When at 100% battery the station shut downs by itself after some time (ECO is off).
@BLUETTI_CARE Could you please also push this firmware to me?
AC180P2344004373471
ARM 2089.02
DSP 2088.02
BMS 1039.01
AC180P2335001646247
ARM 2089.02
DSP 2088.02
BMS 1039.01
Thanks!
Hello, I have updated it, now:
AC180P2349001761850
ARM 2089.03
DSP 2088.03
BMS 1039.01
I plan to use it as a UPS, can I get version 2088.04?
Hello @BLUETTI_CARE.
I received an update (DSP v2088.03) but they sent it to the previous station (DSP v2088.04)
Is there a bug in the firmware, or have you already optimized the update?
Model: AC180P
SN: 2352000574347
ARM: v2089.03
DSP: v2088.02
BMS: 1039.01
To all AC180P owners:
The firmware version DSP2088.03 that solves this AC180P issue has been pushed to everyone’s AC180Ps, please kindly upgrade.
Notes:
@BLUETTI_CARE , thank you for mass rollout of new DSP firmware.
In my application I can see ARM v2089.03 update proposed.
Could you please tell the purpose of it ?
What about FAN issue?
@alexts The main update for the ARM is that when the screen is set to stay on, you can now press the power button briefly to turn off the screen. This is not related to the DSP that was used to address this issue.
