Problem with New AC180P
Updated yesterday
So far, so good
I’ll keep testing and ping here in case of problem return
Dear @BLUETTI_CARE ,
same issue. Could you, please, send me firmware updates as well?
Thanks in advance!
Serial number: AC180P2335001903940
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE.
Could you please provide me a new firmware too?
AC180P2335000595184
ARM: 2089,02
DSP: 2088,02
Hello @BLUETTI_CARE, the same problem.
Please kindly provide the firmware update.
Serial number: AC180P2335000874085
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Dear@BLUETTICARE,
Please update software, my device is:
AC180P2332001354812
ARM V2089.02
DSP V2088.02
BMS V1039.01
Dear@BLUETTICARE,
I have the same issue - the station randomly power off after grid outage.
AC180P2335001175442
ARM V2089.02
DSP V2088.02
BMS V1039.01
The above serial number has been recorded, and the firmware will be pushed within 24 hours.
Dear@BLUETTICARE,
AC180P2352000182927
ARM V2089.03
DSP V2088.02
BMS V1039.01
Hello @BLUETTI_CARE , i have same problem with UPS, the station turns off after a power outage.
AC180P2344000929236
ARM v2089.02
Could you provide a software update please?
Hi @BLUETTI_CARE team! I have the same problem. My device is AC180P2349002015125, ARM 2089,02 DSP 2088,02. Thank you!
hello! Indeed, firmware 2088.04 solved some problems, although during the testing process I found another problem:
If AC180P is used as a UPS for a refrigerator, then there may come a time when there is a long absence of external power, when the battery is completely discharged, it turns off, and when the external power is turned on, only the AC180P itself turns on to charge the battery, but the refrigerator will remain turned off, and this is bad.
How do I get AC180P to automatically turn on AC when external power appears? Is it possible to add the “Default AC on/off” item in the program?
This will fix UPS mode…
s/n 2332001379568
bms v1039,01
arm v2089,02
dsp v2088,04
Пожалуйста, обновите мою электростанцию.
AC180P2341000155494
Версия ARM v2089,02
Версия DSP v2088,02
Dear@BLUETTICARE,
AC180P2335001040553
ARM V2089.02
DSP V2088.02
BMS V1039.01
The above requests will be processed in 24 hours.
have same issue with UPS mode
Please push firmware update on my device:
AC180P2335001241110
ARM V2089.02
DSP V2088.02
BMS V1039.01
AC180P2349001869073
ARM V2089.02
DSP V2088.02
BMS V1039.01
@dimetrius Done, please check.
AC180P2344000371899
ARM V2125.01
DSP V2126.02
BMS V1048.03
Hi @BLUETTI_CARE, I have a similar problem with UPS station turns of, when elecrticity turns down pls help me out, thank u in advance.
AC180P2344004049756
ARM: v2089.02
DSP: v2088.02
Hello @BLUETTI_CARE , I have the same problem with 100% shutting off. Please send me the new firmware. Thanks in advance!
AC180P2341000150076
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
