Please send the new firmware to me too, because… I also encountered the problem of turning off the station under a load of 200 W
S/N: AC180P2349000575473
ARM v2089.02
DSP v2088.02
BMS v1039.01
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, i have same problem with UPS, the station turns off after a power outage.
Can i have latest softwear update?
AC180P2349001446229
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Above request will be processed ASAP.
@BLUETTI_CARE,
Updated DSP to V2088.04, will test, thank you for the quick response!
UPD: about 3 hours passed since the soft update, no shotdowns are detected.
Hey, i have same problem with UPS, the station turns off after a power outage.
AC180P2349000491882
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi, @BLUETTI_CARE,
I once again remind you of my humble request to send me the newest available firmware (2088,04) as the above-described deficiency keeps coming…
Many thanks
P.S. AC 180P2342000542085
ARM version v.2089,02
DSP version v. 2088,02
BMS version v. 1039,01
Hello, @BLUETTI_CARE
I have same problem with UPS, the station turns off after a power outage.
Can I have the latest software update?
AC180P2349001193852
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
You should have received the new firmware, please check again.
Hi @BLUETTI_CARE , my Bluetti has the same UPS problem
AC180P2332001448762
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
@BLUETTI_CARE Sorry for duplicate, but i don’t know if you received notification about update if i mention you when redacted, so i try again
Hi! My Bluetti AC180P is a great device, but I have the same problem with random shutdowns when battery fully charged (ECO not engaged). Can i have this magical firmware to fix that please?
SN: AC180P2349000758862
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Good day. I have same issue, please push me a new firmware
AC180P2335001488587
Arm v2089.02
Dsp v2088.02
Bms v1039.01
Brand new AC180P out of the box and the same issue. Please kindly provide the firmware update.
AC180P2335001652063
ARM v2089.02
DSP v2088.02
BMS v1039.01
The above serial number has been recorded, and the firmware will be pushed within 24 hours.
Updated yesterday
So far, so good
I’ll keep testing and ping here in case of problem return
Dear @BLUETTI_CARE ,
same issue. Could you, please, send me firmware updates as well?
Thanks in advance!
Serial number: AC180P2335001903940
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE.
Could you please provide me a new firmware too?
AC180P2335000595184
ARM: 2089,02
DSP: 2088,02
