EB3A Shuts off at 75% and wont turn back on
Hi @bluetti_hikaruuiojeangmailcom, We care deeply about the issue you raised.
Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Thank you, I’ll let you know.
Hi, I’m done with the firmware update, but it still stops at 44%. I connected it to the grid to turn it on and ran it again, but after a few seconds it turns off. I’ve tried it several times, but it still won’t drain to 0%. I only used an 11-watt device to drain it.
What should be the next steps to resolve this?
The update arrived but the problem remained.
Hi @bluetti_hikaruuiojeangmailcom9 and @Maxfield, Thank you for the update! We acknowledge that the battery level display of your EB3A is inaccurate.
We recommend trying multiple charging methods to help the battery restore to its optimal state: car charging, solar charging, and simultaneous AC+DC charging. After fully charging, leave the unit idle for 3 hours before discharging—does this method work for you?
If the issue persists, repair will be the only viable solution.
Thanks, got the update
After testing for a few days, it now shuts down at 43% instead of 50%. So an improvement, but still not using 100% (or displaying remaining charge correctly, not sure which)
@BLUETTI_CARE
Hello… Could you push the upgrade for me as well? Seeing the same issue at 48%
EB3A2243000298836
ARM: v2063.03
DSP: v2052.11
Hi @BLUETTI_CARE, I have the exact same issue with my EB3A, the power cuts off at 75%.
I’ve done all the troubleshooting steps and no luck.
Could you “push” a firmware upgrade my way?
EB3A2312003013644
ARM v2063.03
DSP v2052.11
Please & Thank You
Hi @msdinit, we wonder if you have recalibrated it after upgrading?
  1. Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
  2. Please charge it again. Please do not load any device when charging it, and do not interrupt it while it is charging.
Hi @Aw3som3, We have requested the firmware push from the technical department as you requested.
Hi @Khule, we have requested the firmware push from the technical department as you requested.
Hello, @BLUETTI_CARE Same problem with my unit. Random shut-offs. have tried usual troubleshooting.
Could you please check firmware upgrade availability?
ARM: v2062.04
DSP: v2056.14
SN: EB3A2342003434819
@BLUETTI_CARE The firmware has been updated to ARM v2063.04 successfully but the device still cuts power at 75%, it won’t drain below that.
Same issue
Already did the drain and recharge 5 times but it has the same issue still.
EB3A2311001349736
ARM-v2063.03
DSP-v2052.11
@BLUETTI_CARE
Hi @ekbrown, Now I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 24 hours.
Hi @Khule, we wonder if you have recalibrated it after upgrading?
  2. Please charge it again. Please do not load any device when charging it, and do not interrupt it while it is charging. Additionally, we recommend trying all charging methods separately, including AC charging, car charging, and solar charging.
I have the exact same issue at 79%, please push the latest firmware to my device too.
EB3A2243001207017
ARM: v2063.03
DSP: v2052.11
@BLUETTI_CARE
Hi @BLUETTI_CARE kindly check my EB3A as well.
Hi @PDagz12, thank you for getting in touch with us.
Hi @BLUETTI_CARE the power still cuts off at 75% when trying to discharge, this is after a firmware update, so I cannot continue with the troubleshooting process because battery cannot reach 0%. What else can I do?
EB3A2312003013644
ARM v2063.04
DSP v2052.11
