Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Ok i think you got mixed up with someone else. I used my eb3a and ran it down to 0%.It the displayed 100% charged but i didn’t charge it.When i tried to charge it will not charge.I read other post where you said that upgrade did not fix the problem.Will this upgrade work?
I apologize for the mix-up! Thank you for your message. Let’s go through a few steps to troubleshoot your issue:
- Please check the firmware version in the app to ensure it’s the latest.
- Look for any error messages on the screen, such as “Temp.” If you see a temp error, please stop charging, disconnect any loads, and place the machine in a cool area for three hours before trying to charge it again. If it’s winter, keep it in a warm place for three hours before charging.
- Check if the Circuit Protector on the right side of the AC input is popped out; if so, press it back in and try charging again.
- See if there are any fault codes. You can check this by turning on the machine and holding down both the AC ON and LED ON buttons.
- If the UPS is flashing, please refer to the next section about “UPS flashing during AC charging.”
- Lastly, confirm if the DSP version is the latest. If it’s not, you can provide the serial number (SN) and firmware information to push the DSP firmware. You can find the SN in the app’s settings page and the firmware information in the “firmware upgrade” page.
I hope these steps help resolve the issue! Let me know if you need further assistance.
I am still in need of the new firmware.
Hello, I have registered the new firmware upgrade for you, please check it.
i brought my EB3A roughly 4-6 months ago & mine shuts off roughly at 43% w/ eco mode off
but i did briefly see an error on the display “short” before going away
appreciate any i could get any help
cheers
Brainiac
Model > EB3A2432001205972
IOT > v9046.04
ARM > v2053.08
DSP > v2052.11
Please check the historical error codes. Here are the steps:
- When an error occurs, long press both the ACON and DCON buttons to enter the settings menu, then long press the DC ON button to view the error codes.
- In the APP information interface, if an “!” icon appears in the upper right corner, you can also check the error codes through it.
If you have any further questions, please let us know!
Hi, could I get a firmware push as well? I’m having the same issue.
EB3A2334004026959
ARM: v2062.04
DSP: v2056.13
Greetings from germany.
I have the exact same problem too. My EB3A is constantly shutting down and if i plug it on AC its immediatly going on again at 71%.
Looks like the exact problem everyone else is having. The App says its the actual firmware.
I would really like to get the firmware update pushed to be able to use the unit again. thx in advance.
S/N: EB3A2252003130403
ARM: 2053.08
DSP: 2052.11
anyone?!
is this thread dead? no support anymore?
@BLUETTI_CARE Mine is currently doing the same , but sometimes it shuts down around 75, 45 and last night was 35% and won’t come back on until i plug it in to charge and when i plug it in to charge it always show 94%
sn# EB3A2214000086513
FIRMWARE: ARM v2057.11 ; DPS v2056.10
any help is welcome
Hi @fartsquirrel, thank you for letting us know.
could you do the same for the other posts above him pls? ![]()
Hi @YumYumTuete, we would like to help you.
@BLUETTI_CARE
I have the same issue @65%
sn: EB3A2443000993329
IoT: v9046.04
arm: v2118.09
DSP: v2117.08
How do I fix this, pls?..
@BLUETTI_CARE
Could you push the upgrade for me as well? Seeing the same issue at 50%
sn# EB3a2309000480626
Firmware: ARM: v2053.08 DSP: v2052.11
I have the exact same issue, please push the latest firmware to my device too.
EB3A2316000397815
ARM: v2063.03
DSP: v2052.11
Hi @msdinit, thank you for letting us know.
Hi @Maxfield, thank you for getting in touch with us.
