EB3A Shuts off at 75% and wont turn back on
Hi @Sky, Can you remedy the trouble using the procedure?
Please plug the EB3A into the AC home grid to be charged, and charge until it is 100%.
After that, please turn on the AC and DC of the EB3A. After 30 minutes to 1 hour, the EB3A will drop from 100% to 99% due to self-consumption.
After the SOC of EB3A drops to 99%, please unplug the AC charging cable of EB3A from the home grid to see if the EB3A can be turned on normally. If so please AC charge the EB3A again.
Normally, the EB3A will work well, and please tell us the EB3A’s DSP, and ARM version, we will push the new firmware to avoid this problem happen again.
2056.10 DSP
2062.03 ARM
And I’ll try the fix you recommended but as I said, it’s having trouble staying on, even with the AC power connected
@BLUETTI_CARE
It keeps turning off before I can get it to drop any voltage I even tried to load drop the voltage.
Hi @Sky, Thank you for getting back to us so quickly.
Please test it by continuing to AC charge and keeping the output on for 30 minutes to an hour.
If the issue is resolved, please notify us, and we will push new firmware to prevent the problem from recurring.
If the issue persists, you may need to contact customer support to arrange for a repair.
I appreciate your kind understanding and patience.
I don’t think you understand lol, I plug it into AC power and turn on the AC output (no load) and within 20 seconds it shuts itself off. I can’t leave it for the recommended 30 minutes - 1 hour. And it shuts off so quickly that it doesn’t have time to drop any soc from self consumption. @BLUETTI_CARE
Hi @Sky, I am sorry for the inconvenience.
It seems this method isn’t effective for your EB3A. We recommend directly contacting customer service to arrange for a repair.
If you’re unsure about how to contact customer service, please send us your order details via message, and we will arrange for the support team to reach out to you and follow up on this matter.
@BLUETTI_CARE it’s saying I do not have the permission to private message you, am I doing something wrong?
I have the same problem. I charge fully normal mode to 100%. I decharge and when it come to 75% the bluetti stop ant won t turn on.
Help please
EB3A2308010821459
ARM v2053,08
DSP v2052,11
Hi @NC026, Apologies for the delayed response due to a heavy workload recently.
I have applied to upgrade your firmware to our IT department. They will push the latest firmware version to your machine in 24 hours.
Please upgrade it tomorrow.
Hi,
I still not have receive the latest firmware
EB3A2308010821459
ARM v2053,08
DSP v2052,11
Hi
still no firmware upgrade in my app
EB3A2308010821459
ARM v2053,08
DSP v2052,11
Help please
EB3A2308010821459
ARM v2053,08
DSP v2052,11
  • still not have receive the latest firmware
Hi @NC026, We apologize for the delayed response due to the holiday.
We have consulted with our technical engineer regarding this matter, and he informed us that the new firmware cannot fix the issue. Therefore, we recommend contacting customer service to arrange for a repair.
I hope it does help.
Hello @BLUETTI_CARE I am having the same problem, can you push a new firmware?
EB3А2225003903898
ARM v2057.11
DSP v2056.10
Hi @bluetti_rexlingmailcom, Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
@BLUETTI_CARE Hello, I applied the update but battery still shutting off at 50% It was shutting off at 75% before
Hi @bluetti_rexlingmailcom, Thank you for your feedback. It seems that the new firmware didn’t help. In that case, I’m afraid you’ll have to contact the customer service to arrange for the warranty.
Hello @BLUETTI_CARE I am having the same problem at 47%., Could you please push a new firmware?
EB3A2326004457523
ARM v2062.03
DSP v2056.13
Thanks.
Hi @Pcevalloswu, We’d like to understand the specifics of the issue.
It seems that your EB3A automatically shut down at 47% battery and can’t be powered on again— is that correct?
Could you let us know:
  • Are there any error codes displayed in the app or on the screen?
  • What load was connected when the issue occurred, and what was the specific power?
  • Did removing all loads and restarting resolve the problem?
  • When connected to a grid power source, does the screen light up?
It would be helpful if you could record a video, upload it to a cloud drive, and share the link with us.
We need to resolve the issue and ensure normal charging and power-on before proceeding with firmware upgrades. This will help us accurately diagnose the root cause.
Please provide the information above at your convenience.
Hi,
Yes, the EB3A automatically shut down at 47% battery and can’t be powered on again until connected to a grid power source.
  • No error codes on the app or the screen.
  • only charging a cellphone with AC.
  • The device only turns on when connected to a grid power source. After that it works until 47% , then it turns off again.
Thanks for your support.
