Can not change AC on/off and DC on/off bluetti ac200max
Hi, I have the same problem with my AC200MAX. First power on it was working, on the next day it sopped. I have updated DSP and BMS via app, but it still isn’t working and there’s no update for ARM.
@BLUETTI_CARE Can it be fixed with software update?
@yaroslaw I have registered your machine issue, and the firmware will be pushed within 24 hours.
@BLUETTI_CARE isn’t it strange that I have the exact same versions of DSP, ARM, BMS and HM1 as posted above in this thread, but I can’t receive the firmware update to fix the same problem?
Hi @Zhyrnov, Your AC200MAX’s hardware batch is different from other batches, so it cannot receive the new firmware and therefore cannot be upgraded to resolve the issue. We recommend contacting customer support to arrange a screen repair.
Thanks, after the update it works as it should.
Hi @BLUETTI_CARE ! Have exact same problem on my AC200MAX. AC\DC buttons just not working(
SN: 2252002451344
DSP: 4005.08
ARM: 4008.05
BMS: 1017.03
HMI: 6037.04
Hi @Goshe, I have applied to upgrade your ARM to our IT department. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
I have a brand new unit that is doing the same. There is also a small lock icon on the home screen next the homepage icon. pushing AC on does not function with the Touch screen or app.
please may you help
Hi. I have the same problem with my AC200MAX. Please push me upgrade for my Bluetti. Thank you and best regards!
photo_2024-09-23_09-53-16
Hi @Zim, We would like to know if you purchased this machine outright or through a Paygo subscription. If it was a full purchase, please message us and provide valid order information so we can unlock it for you.
If it was through Paygo, that’s normal; as long as you make the payment for unlocking on time, it will be fine.
If you need our help, please remember to @BLUETTI_CARE, otherwise, I may not find your reply in a timely manner.
Hi @Kuripka, Your AC200MAX’s hardware batch is different from other batches, so it cannot receive the new firmware and therefore cannot be upgraded to resolve the issue. We recommend contacting customer support to arrange a screen repair.
Greetings
Thanks for replying, I went back to the vendor and was supplied an unlock code. It was bought outright. All is working. Thanks for the @ tip , learning as I go
Best regards
Hi @Zim, Thank you for letting us know, I am glad to hear that the problem is resolved. :)
Hello @BLUETTI_CARE ,
unfortunately I have had the same error as described here since the last firmware update.
I already contacted the mailbox “sale-de@blettipower.com” on January 13, 2025, but have not received a response yet.
Is it possible to push new firmware? Or is there any other way to contact the service?
Here is the serial number etc.:
Regards,
René
Hi @deeba_de, We apologize for the delayed response due to the holiday.
We have consulted with our technical engineer regarding this matter, and he informed us that the new firmware cannot fix the issue. Therefore, we recommend contacting customer service to arrange for a repair.
I hope it does help.
@ Bluetticare, i have recently purchased a Bluetti 200Max, fist use the ac and dc power buttons on screen wont switch on.
Sn: 2315000044203
DsP : 4005.08
Arm : 2040.04
Bms : 1017.03
Hmi : 6045.03
I can not chance DC on/off or AC on/off on the display.
I can change it only through my mobile phone app via bluetooth.
Serial Number: AC200M2228002563679
In Germany 220 Volt
What can I do? Do you have a update ?
Thanks for you answer.
Best regards
Thomas
Hi Thomas, We are very happy to assist you.
Could you please tell us the current ARM version of your AC200MAX? We will then push the corresponding new firmware based on this information.
Hallo,
Danke für Ihre Antwort.
ARM V 4008.03
BMS V 1017.03
