Hi, dear admins. Plz, could make available latest firmware for my EB3A. In Ukraine, where I live, this question soon we’ll be urgent, so, plz, give it to me. My issue is — not working properly wireless charging with iPhone 13. It starting charging, but then stops in about 3-5 minutes.
Current firmware are:
ARM v2053.07
DSP v2052.09
Serial: EB3A2302007409333
please provide me also with new firmware. i know that the exact same fridge works with this powerstation from a friend of mine. so please push firmware also to me. everyone else gets new firmware, why do i dont get it?
version is
Oh…ok… I’ll wait though.
One more question, plz. I noticed, when I use solar panels with my EB3A, everytime it charges to 100% it’s powering off the AC for a moment. Could it be solved in next updates? Cause it makes problem for TV or display — it’s going of for about a second. Thank you.
Update was easy, but still PV Input (from car Plug) is around 30-46 Watt. Sometimes in goes up to 105 Watt for a few seconds, then drops to under 20 Watts. Maybe something is overheating inside? AC Input from 230 Volt is good with 200-260Watts.
Kindly requesting a firmware update push to avoid future issue as reported by other users with the same firmware as me of unit discharge when solar panels are partially shaded.
Country: Canada
ARM Version: 2057.11 DSP Version: 2056.10 Serial #: EB3A2218000017404
Country: UK
ARM Version: 2053.07 DSP Version: 2052.09 Serial #: EB3A2307004692726
@Powerlifting When charging, turn on the AC and DC keys. After 30 minutes to 1 hour, EB3A will drop from 100% to 99% due to self-consumption. At this time, unplug the charging cable to see if it can work normally (it can also be turned on if you unplug the charging cable).
Dear Bluetti Support,
Please push also the Firmware Update for my device.
Serial number: EB3A2226000063557
I am not able to charge from solar although I’ve tried several different 12v panels and cables. No current received by the device at all.
Thank you!
