same here. no new firmware. I need especially because the fan turns on also if I have nothing connected and the device is in ups mode. is it normal? the device is installed in a camper and it is a bit noisy during the night
@mebitek Fan start is normal and cannot be fixed by firmware.
Fan start is affected by temperature, charging power and discharging power. If one of these conditions is met, the fan will start.
Check what steps? Other than the email I received stating the firmware had been pushed to my device, I haven’t seen nothing in the app that suggests anything was sent to me.
Hi there, EB3A2251003062258 my Eb3a with .07 Firmware has problems with ups Function, and only 20-50W Input from car plug most of the time. Possible is around 100-120W which only Works sometimes.
I bought the Eb3a with the 100 watt solar panel from amazon as part of prime day I have not been able to charge with the solar panel will I need new firmware update also the Eb3a discharges itself for no reason I have code 3-06 showing on the panel
please push latest firmware to my device, i am also in the EU / EU version
got some problems with dc output ot powering my mobile fridge with 12v. works perfectly in my car, but not with eb3a
please push latest firmware, so i can test if problem is solved. thanks
