Device was purchased a week or two ago and used with the constant AC load ~150W in UPS setup
When electricity from grid is turned off AC180P sometimes also turns off and does not respond for a 5-10 seconds(backlight and screen also turn off and does not respond)
I would say that it happens approximately once per day and also noticed that it’s usually happens when AC180P is working from grid in mode described above for a 5+ hours and after that grid power disappear
Config:
Charging mode standard
DC-ECO disabled
Power lifting disabled
Grid self-adoption disabled
I have the same problem with the shutdown
AC1802410020404997
Eco disable
Errors code E0092 E0000
IOT - 9046.01
ARM - 2124.02
DSP - 2126.02
BMS - 1052.02
I have the same problem…
when at 100% battery and losing power from the grid the station shut downs by itself (sometimes). Please send or push this new firmware update to me.
Hello @BLUETTI_CARE!
I have the same problem.
“when at 100% battery and losing power from the grid the station shut downs by itself (sometimes).”
Please help me.
Please help me.
AC180P2349001583695
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
