Hi, @BLUETTI_CARE!
Have the same issue and the same symptoms.
please provide firmware update too
S/N AC180P2335000866587
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi, @BLUETTI_CARE!
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi, @BLUETTI_CARE!
S/N AC180P2349000473996
ARM v2089.02
DSP v2088.02
BMS v1039.01
I have the same problem. Please provide me with apdated firmware
AC180P2344004191931
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi, @BLUETTI_CARE!
For some reason my newly bought device have the same issue: “With full charged battery and losing power from the grid, the station shut-downs by itself”
Could you please push new firmware for me too? Thanks
Model: AC180P
SN: 2335001517721
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE!
My Bluetti AC180P turns off when the mains power goes out. The same problem is being discussed on the forum. Please send me the updated firmware.
S/N AC180P2341000325947
ARM-v2089.02
DSP-v2088.02
BMS-v1039.01
I have the same problem: shuts down when it’s charged
AC180P2348001048622
ARM v2089.02
DSP V2088.02
BMS 1039.01
I have the same problem my Bluetti AC180P turns off when the mains power goes out. Please send me the updated firmware.
S/N AC180P 2342000823906
ARM-v2089.02
DSP-v2088.02
BMS-v1039.01
Thank you
Hey, could you also push new firmware to me? Thanks!
AC180P2349002138598
ARM: 2089.02
DSP: 2088.02
BMS 1039.01
Hi, @BLUETTI_CARE
Faced with the same problem.  Could you send me firmware update with fix?
S/N: AC180P 2335002023717
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello everyone, for customers above who have already provided the SN code and DSP version, I have requested the new DSP v2088.04 to be pushed. This will be completed within 24 hours. Please check if you received the new DSP v2088.04 in your Bluetti APP, upgrade the firmware, and test if the issue is resolved. Please do not load any device when upgrading it.
We plan to push the new DSP v2088.04 firmware in bulk within this week.
If all goes well, customers will not need to provide their SN code for a separate push. Instead, they will be able to log in to the Bluetti app and upgrade on their own.
Привіт@BLUETTI_CARE!
У мене та ж проблема.
«при 100% заряді батареї та втраті живлення від мережі станція вимикається сама постійно».
Будь ласка, перешліть нову прошивку.
Дякую!
AC180P2332001200593
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
Hello
I have same issue with shutdowns
Could you send firmware update to me?
AC180P2352000664714
ARMv2089.03
DSPv2088.02
I have the same problem: it randomly turns off when the grid disconnects in UPS mode. Please push the new firmware. SN:
AC180P2344003056736
ARM V2089.02
DSP V2088.02
BMS v1039.01
“when at 100% battery and losing power from the grid the station shut downs by itself (sometimes).”
AC180P2342000142950
ARM v2089.02
DSP v2088. 02
BMS v1039.01
AC180P2344003056736
ARM V2089.02
DSP V2088.02
BMS v1039.01
У меня та же проблема: он случайно выключается, когда сеть отключается в режиме UPS. Пожалуйста, пришлите новую прошивку. СН:
AC180P2344003056736
АРМ V2089.02
DSP V2088.02
BMS v1039.01
I have received and tested (one day until now) the new DSP v2088.04 firmware - the problem with switching off at 100% SOC and greed off seems to be solved. Tank you!
Hello @BLUETTI_CARE
Have same randomly shut down issues in UPS mode on my AC180P when on 100% power state and after grid power loss.(DC - off / AC - on / power lifting - on / ECO AC/DC - off Grid self-adaptation - on)
Also noticed a fan bug, when they sometimes off and don’t spin, on low power draw (<105W), and after some time push to MAX speed, and never spin down to lower state till i turn off/on the station
Please share new firmware
ACP180P2344000469144
ARM v2125,01
DSP v2126,02
BMS v1048,03
I also had a problem during the operation of the station in UPS mode, please provide firmware update.
S/n ac180p2349000192450
ARM v2089.02
DSP v2088.02
BMS V1039.01
