@BLUETTI_CARE , why don’t you push new update for everyone, lots of people having same issue… I have it too - new AC180P is working in UPS mode, when the grid turns off it randomly can immediately turn off , you can’t turn it on it for few seconds, then after turning it on it shows incorrect w load (more than 1000, when in fact its just a fridge and other devices connected that can theoretically consume less than 300 w in total only in my case)
Eco mode = off, autosleep = never, power lifting = on, charging = standard, AC and DC on with some constant load
Wrong, the fans keep spinning forever like it’s over 1000 watts of the constant load until I increase the wattage to get over 15 watts, and after that the fans slow down. That is anything but optimal behavior. I keep my PC on all night to not get woken up by the fans.
Also, why the station doesn’t show the wattage under 15 watts in the first place?
If the fan problem has been optimized in the past, there’s still room for improvement because it’s really annoying. I have 2 much cheaper Chinese 600wh power stations that stay dead silent on sub 15 watts.
AC180P2335000461932
I bought a Bluetti AC180p charger. I use it as ups for my PC. For some reason, if my power goes out, the device also turns off and I have to turn it back on. What could be the problem. Thank you.
When at 100% battery the station shut downs by itself after some time. @BLUETTI_CARE Could you please also push this firmware to me?
AC180P2335001106275
ARM 2089.02
DSP 2088.02
BMS 1039.01
Good afternoon. I have the same problem, after charging to 100 percent it turns off even with a consumption of 220. The ups mode does not work correctly, I need help. The DSP firmware version costs 2126.02. ARM 2125.01
Thank you
