Have the same issue. @BLUETTI_CARE can you push update for me?
AC180P2332001299066
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
AC180P2332001299066
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi, My AC180 is now quite old and I don’t use it very often but, I’m having the same problems as many others. The firmware is also old but it doesn’t show there are any updates available. Does everyone have to request an update individually? This would seem crazy!
AC1802315000335572
ARM V2074.07
DSP V2078.08
BMS V1033.12
@LeadDog AC180 and AC180P are different stations and the firmware for them is not compatible with each other. I think it’s better for you to either find a similar topic for AC180 or create a new one.
Same problem, please share the firmware.
AC180P2332001495816
AC180P2349001391601
Hello @BLUETTI_CARE ! Please send me new firmware update for my AC180P for better UPS mode experience :)
Model: AC180P
SN: 2349001733796
ARM v2089.02
DSP v2088.02
BMS v1039.01
@BLUETTI_CARE How I will notified about sending me new firmware? Check for updates in Bluetti APP ?
Because you wrote “The above request will be processed in 24 hours” but there is no updates.
Good afternoon, today the power went out when the computer was working through a station connected to the network, and it turned off. ECO was turned off.
Can you send me an update?
AC180P2349000700978
ARM v2089.02
DPS v2088.02
BMS v1039.01
Для Bluetti AC180P требуется новая версия прошивки
SN 2335000467888
ARM v2089.02
DSP v2088.02
BMS v1039.01
Спасибо за помощь.
Hello!
I just received the device. Heard that the issue is very common, so kindly asking to push the 04.firmware with the fix to my charger as well.
SN: AC180P2342000087556
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi, I have the same problem. Could you please send me an update?
AC180P2349002047497
ARM - 2089,02
DSP - 2088,02
BMS - 1039,01
The above serial number has been recorded, and the firmware will be pushed within 24 hours.
The fan problem has been optimized and pushed to all machines in batches before. There is no updated firmware at present. I think it may be that the temperature has not dropped. The fan will be turned off only when the temperature drops to a certain range.
Привіт
Хочу також отримати нову прошивку,бо є проблема з відключенням
ARM 2089.02
DSP 2088.02
AC180P2344004248780
Дякую
I have the same problem:
AC180P2335000677206
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi! @BLUETTI_CARE
I have the same problem. Please, send me a new firmware to fix it.
AC180P2349001631377
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please, help me to fix this issue.
Thanks!
Same problem
Arm - 2089,02
Dsp - 2088,02
Ac180p2344002046903
Give me update pls
Добрый день У меня та же проблема. Пожалуйста, пришлите мне новую прошивку, чтобы это исправить.
AC180P SN 2335000845926
ARM v2089.02
DSP v2088.02
BMS v1039.01
Пожалуйста, помогите мне решить эту проблему.
Спасибо!
Пришлите новую прошивку, пожалуйста
АС180Р2344002046903
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please send the update of firmware
AC180P2344000475786
hi @BLUETTI_CARE ! Same issue for me, please provide with the updated firmware:
AC180P2344000860966
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Thank you!
Kind regards,
Inna
