Hello, @BLUETTI_CARE
Could you please send firmware update for my station AC180P. I have the same problem with turn off randomly in UPS-mode.
SN: AC180P2332001345293
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
@john222 I’m sorry about that. Your request has been processed twice. Please check if you have logged in with your account, and connect via Bluetooth.
@john222 I found the problem, the SN you have provided is wrong. The firmware will be sent in 24 hours again. Please wait a few times. Thanks.
Hello! @BLUETTI_CARE
Update the firmware on my AC180P for stable operation.
AC180P2341000268035
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thank you
I have the same issue. Send me please update the firmware on my AC180P for stable operation.
AC180P2332001231054
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thank you
Same problem, please provide new firmware
AC180P2342000022040
ARM 2089.02
DSP 2088.02
BMS 1039.01
Same issue. Please send me update for my AC180P.
AC180P2344000711958
ARM v2089.02
DSP v2088.02
BMS v1039.01
Get similar problem in UPS mode. Send me update please
AC180P2349000424571
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi, same problem, AC180P turns off in UPS mode (ECO off).
SN - AC180P2344000379130
ARM - v2125.01
DSP - v2126.02
BMS - v1048.03
Hello
I have same issue with ups mode
Could you send firmware update to me?
S/N AC180P2344000859378
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P2344000894762
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P2341000199120
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thank you
Please send me an update go version 2088.04
AC180P2344003060924
ARM v2089, 02
DSP v2088, 02
BMS v1039, 01
The above requests will be processed in 24 hours.
I would also like to receive the update to fix same problem
AC180P2344000746974
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello. I’ve noticed 2 problems on the new firmware. I constantly get low grid voltage error even when voltage is around 195 volts (even in Silent mode and Grid Self-adaptation on). When I have this error device doesn’t charge itself and pass-through function stops working so my appliances are powered by the power station even when I don’t have any power outage in the grid. This is very inconvenient!
Hey, I have the same problem as described above. When at 100% battery and losing power from grid the station just shut downs by itself. Could you please also push this firmware to me?
AC180P2335000605126
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
I have the same problem: it randomly turns off when the grid disconnects in UPS mode. Please push the new firmware.
SN: 2332001192503
ARM
Current Version:v2089.02
DSP
BMS v1039.01
Current Version:v2088.02
As I understand it, I need the new firmware 2088.04
Hello! I have the same UPS problem with my device.
Serial: AC180P2332001412074
ECO off
ARM v2089.2
DSP v2088.2
BMS v1039.01
Could you please send me new firmware? A lot of thanks
