AC180P turns off randomly
Good day! Error E117 also occurs when charging from a 220V outlet. The latest firmware is available. Do I need a DSP upgrade too? How and where to download it?
@BLUETTI_CARE Hello!
I Have the same problem, could you please push me firmware update?
AC180P2349000662708
ARM 2089.04
DSP 2088.03
BMS 1039.01
Thank for your help
Добрый день. В режиме UPS временами заряд опускается на 99% и дозаряжает, 1 раз самопроизвольно выключилась, при отключении света в режиме UPS если станция работает больше часа то выключается если меньше часа переключается на батарею.
AC18002422001331639
IOT 9046.04
ARM 2124.04
DSP 2126.02
BMS 1052.02
Hi @Artem5, has your AC180P also been experiencing random shutdown issues?
Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Hi @BayanOleh, We have a new firmware update available that addresses this issue, though it has not yet been rolled out to all users.
If you require this update, please provide us with your device’s SN Number and current firmware version. We will then push the update to your device individually.
Hi @lea.dp.ua, now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Hi @AMRA, now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
hi @BLUETTI_CARE PS, in UPS mode, my AC180P, if the network is 180-190V and there are voltage surges, suddenly turns off for half a second, which causes temporary disconnection of devices connected to it. Adaptation to the network is enabled, silent charging is used. If possible, please update the firmware
AC180P2428000840654
IOT v9046.04
ARM v2125.04
DSP v2126.04
BMS v1048.05
Hi @Robyt, we would like to help you.
arbitrary shutdown of the station after updating
AC180P2344000543118
ARM v2089.04
DSP v2088.04
БМС v1039.01
I forgot to specify that my model of the power station is the ELITE 100V2.
Hallo!
SN EL100V22525004010172
ARM v2186.15
DSP v2200.14
BMS v1083.07
Could you please tell me whether I will receive a notification when the update is available, or how the update process will work?
I have already sent you the serial number and the current firmware codes as you requested, but unfortunately, I have not received a reply yet.
My power station charges very inconsistently: sometimes it starts charging, but then an error appears and the charging stops. That’s why it’s very important for me to receive this update.
Thank you very much for your assistance!
Hallo!
ARM v2186.15
DSP v2200.14
BMS v1083.07
Hello.
SN AC180P2344000940257
ARM v2089.04
DSP v2088.03
BMS v1039.01
Please help me solve the problem with constant reboots and shutdowns in UPS mode.
Hello. Thank you for upgrading. I installed latest version, but the problem did not disappear completely. The station stopped turning off as often as before, but the problem of random shutdowns remained. What else can I do?
AC1802313001001848
ARM v.2074.08
DSP v.2078.07
BMS v1033.12
Hi @Stalkerua1, Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Hi @BayanOleh, Thank you for the update. If your model is the Elite 100 V2, we recommend following the troubleshooting steps below first:
  1. Could you please let us know your region and whether the power grid is stable?
  2. Please access Advanced Settings and enable Grid Self-adaption. Did this help?
  3. If the issue persists, adjust the input voltage threshold step by step. Additionally, enable Silent Charging Mode. Did these settings have any effect?
We look forward to your reply.
Hi @Artem3, Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Hi @YaroslavSSS, Thank you for your feedback.
We have submitted it to the Technical Department and R&D Department, and we will contact you as soon as we receive a response.
hi @BLUETTI_CARE ! Same issue for me, please provide with the updated firmware:
AC180P2335002102089
ARM: 2089.04
DSP: 2088.03
BMS: 1039.01
