Hey, I have a problem. When at 100% battery and losing power from grid the station sometimes shut downs by itself.
Could you please also push this firmware to me?
AC180P 2428000440970
ARM 2125.02
DSP 2126.02
IOT 9046.01
ARM 2125.02
DSP 2126.02
IOT 9046.01
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2433001810657
ARM: v2089.02
DSP: v2088.02
BMS: V1039.01
Hello @BLUETTI_CARE . Could you please send new firmware version to me? Thx!
SN: AC180P2432000097562
ARM: v2125.03
DSP: v2126.03
BMS: V1048.05
Hello @BLUETTI_CARE. sometimes i got low grid voltage error, could u plese send me latest firmware verstion?
SN: AC180P2341000737905
ARM: v2089.03
DSP: v2088.04
BMS: V1039.01
Hello @BLUETTI_CARE . Could you please send new firmware version to me? Thx a lot!
IOT: v9046.01
SN: AC180P2432000031041
ARM: v2125.03
DSP: v2126.03
BMS: V1048.05
Hi @VLADIMIRSKIRDA1, We have already pushed the new firmware several times. If you haven’t received it yet, it might be because your Bluetti account is not properly registered or your AC180 is not correctly linked.
Could you provide a screenshot of the upgrade interface, so we can help troubleshoot the issue?
У мене така ж проблема…
коли при 100% заряді батареї та втраті живлення від мережі станція вимикається сама Надішліть або надішліть мені це нове оновлення мікропрограми.
ac180p234004113480
ARM: 2089,03
DSP: 2088,03
BMS: 1039,01
Hi @DR_S, we found that your AC180’s SN number is not completed, so we can’t push the new firmware for you.
Can you check it again?
To this problem, we suggest you upgrade the firmware and then calibrate the battery.
Hi @Eduard_1, we found that we have pushed the new firmware on Sept, and you have upgraded successfully. Does the new DSP v2126.04 works well?
Can you confirm it again?
Hi @Maks0902, we have pushed the new firmware DSP: v2088.03 batchly, can you log into your Bluetti app and upgrade it directly?
Hi @deadlike, we found that your DSP is already the latest one.
We suggest you log into the app, enable the “Grid-self Adaption Mode” in the “Advanced Setting”. Does it help?
Hello everyone, we have applied to upgrade your DSP to our IT department for the customers who have already provided their SN codes and DSP information.
They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
please new software to AC180P2432000015974
IOT v9046.01
ARM v2125.03
DSP v2126.03
thanks
Hi @masjuk and @VLADIMIRSKIRDA1, We have applied to upgrade yourfirmware to our IT department.
Привет! Прошивка обновилась до версии v2088.04. При каких параметрах верхнего и нижнего напряжения станция должна хорошо работать с этой прошивкой ?
Hi @VLADIMIRSKIRDA1, The advantages of the new DSP are:
Everything is fine, it doesn’t turn off -)))))
