AC180P turns off randomly
Hi guys. Could you send firmware update for my station?
AC180P235200000540
ARM v2089.03
DSP v2088.03
BMS v1039.01
Thank.
Hi @BLUETTI_CARE
My station:
AC180P
SN: 2341000861617
ARM: 2089.04
DSP: 2088.04
BMS: 1039.01
My friend already have next versions:
ARM: 2125.02
DSP: 2126.04
BMS: 1048.03
Can you please push new firmware version to me?
And can you do this automatically, because it is awful support when I have to ask you each time for upgrading my station. Thank you!
@BLUETTI_CARE
Hello. The same problem as everyone else has.
Please send a new firmware. Thx a lot.
SN: AC180P2428000928971
ARM: v2125.02
DSP: v2126.02
BMS: v1048.03
Hi @Sydenham, We guess that your AC180P is the U.S. version, correct? We have already pushed DSP v2088.03 to the European version of the AC180P in bulk to address this issue. Since this problem occurs more frequently in Europe and less so in low-voltage regions like the U.S., a separate update is needed.
we have applied to upgrade your DSP. Our IT department will push the latest firmware to your machine in 24 hours. Please upgrade it tomorrow.
Hi @luk_d and @Ludmila, Can you tell us why you want to upgrade the firmware?
We found that your DSP is very new.
If there is no problem, we don’t suggest you upgrade the firmware.
Hi @f45, Can you tell us why you want to upgrade the firmware?
We found that your DSP is up to date.
Hello everyone, we have applied to upgrade your DSP for the customers who have already provided their SN codes and DSP information. Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Привет! Мой BLUETTI просит обновления .Ошибки Е114 Е117.Перепады напряжения.АС180З2352000501130 АРМ v2089.03 DSP v2088.03 BMS v1039.01
I want to use my DSP as UPS. So I need 2088.04 firmware.
Please, send me it.
Hi @VLADIMIRSKIRDA1, Error E114 indicates low grid voltage, and E117 also means low grid voltage. This is an issue with the grid itself.
we have applied to upgrade your DSP. Our IT department will push the new DSP to your machine in 24 hours. Please upgrade it tomorrow.
After that, please change the charging mode to Silent Mode.
In the Bluetti app, enable the Grid-self Adaption Mode in the “Advanced Setting.”
Please feel free to contact us if you need more help.
Hi @Ludmila, we have applied to upgrade your DSP. Our IT department will push the new DSP to your machine in 24 hours. Please upgrade it tomorrow.
Dear friends, please update the firmware of my Bluetti to avoid the shut downs
AC 180P2428001058157
IOT v9046,01
ARM v2125,02
DSP v2126,02
Привет! Обновление на мой Bluetty я НЕ ПОЛУЧИЛ !
Hi! I am going to use my AC180P power station as UPS and have outdated firmware version on it.
Please, could you send firmware update to me?
AC180P2434000500792
IOT v9046,01
ARM v2125,03
DSP v2126,03
Hi! I use my AC180P power station as an UPS. It used to work fine. But now it turns off.
Could you please send me a firmware update that will fix the shutdown?
AC180P2344000443614
ARM v2125.01
DSP v2126.02
BMS v1048.03
I am in the second day of a power outage. I plugged in our separate freezer and frig to our AC180 charged at 100%. I woke up to find the AC 180 had shut off at 41% remaining!!! Frig temp is at 58 degrees. What’s up?
Thanks in advance to your feedback.
SN - AC180233400200
ARM - V2073.04
DSP - V2077.06
BMS - V1033.12
Привет! Обещали прислать обновление в течении 24 часов. Прошло 6 дней а обновления еще нет !
Hello, could you please send me the newest firmware? Thank you
SN - AC180P2352001073703
ARM - v2089.03
DSP - v2088.03
BMS - v1039.01
Привет! Сколько еще нужно ждать обновление ???
Hello!
I have the same problem with the UPS: turned off when grid is down.
Kindly ask you to sent the new firmware to my device
Model: Bluetti AC180P
SN: 2428000859925
IoT: v9046.01
ARM: v2125.02
DSP: v2126.02
BMS: v1048.03
