Hi @john222, can you tell us why you want to upgrade the firmware?
We found that your DSP is the latest one.
If there is no problem, we don’t suggest you upgrade the firmware.
Hi @SVitalii, Yes, it is. The DSP v2126 and v2180 involve different hardware batches, so the latest firmware versions are also different, but there is no functional difference between them.
We have already pushed the latest firmware to your AC180P. Please let us know if the new firmware works.
Привет @VLADIMIRSKI RDA1, я рад это слышать! Спасибо, что сообщили нам.
Hi @Georgset, can you tell us why you want to upgrade the firmware?
We found that your DSP is very new.
Hello everyone, we have applied to upgrade your DSP for the customers who have already provided their SN codes and DSP information. Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Maybe you have an autostart function for the charging station?
If it is completely discharged and voltage is applied to the input, then why not turn on the outputs too?
I’m expecting new firmware too. Thx a lot.
AC180P2428000986884
ARM v2125.02
DSP v2126.02
BMS v1048.03
Hello! My AC180P charging station turns itself off in uninterruptible power supply mode when external power is lost. Please send me new firmware to fix the problem. Charging station AC 180P, serial number 2428000788024 IOT v9046.01 ARM v2125.02 DSP v2126.02 BMS v1048.03 Thank you!
Hello, no updates in 24 hours. Just wait more?
Turning the old firmware 2088.03. It didn’t help. You can delete the notification.
Hi @Serhii08, we have applied to upgrade your DSP. Our IT department will push the latest firmware version to your machine in 24 hours. Please upgrade it tomorrow.
Hi @Bussel and @ACrow, We have previously pushed the new firmware, but it seems you didn’t receive it. Therefore, we have re-sent the update.
If you still haven’t received it, the issue might be related to our server not updating in time. We recommend trying again in a few days.
Hi @alexvovk0604, We have deleted the upgrade notification as requested, so you will no longer be disturbed.
Please feel free to contact us if you need more help.
I have 30 bluettis with this same issue. How can I get the firmware to update them? The app shows them as up to date but it is not the firmware mentioned here as a fix.
2340000429461
ARM
v2087.02
DSP
v2086.02
@BLUETTI_CARE @BLUETTI
Hello, Could you please send me a new firmware with the fix? Thank you
SN: AC180P2349001976816
ARM: v2089.02
DSP: v2088.04
BMS v1039.01
AC180P2428000780541
ARM v2125.02
DSP v2126.02
BMS v1048.03
It works.
Thank you.
Hi guys. Could you send firmware update for my station?
AC180P2332000924412
ARM v2089.03
DSP v2088.03
BMS v1039.01
