Привет! Пожалуйста, отправьте обновление прошивки для моего устройства.
AC180P2428000792733
IOT 9046,01
ARM 2125.02
DSP 2126.02
BMS 1048.03
AC180P2428000792733
IOT 9046,01
ARM 2125.02
DSP 2126.02
BMS 1048.03
After firmware update, there have already been several shutdowns, and after 3-5 manual disconnections, the station keeps working in UPS mode just fine.
Hi @vvv80, can you tell us why you want to upgrade the firmware?
Your DSP is already the latest one.
Hello everyone, we have applied to upgrade your DSP to our IT department for the customers who have already provided their SN codes and DSP information. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Thanks a lot! I tested it for two days! No problems in 2 days!
Привет.
Если вы использовать будете как UPS ,то есть смысл обновиться ,там решена проблема отключения батареи когда подключено что то к ней.
Если вы используете в режиме батареи ( если вы подключаете сами к батарее сами ) ,то вам сильно не будет нужно…
НО если обновитесь - плохого ничего не случиться.)))
Удачи
Is only DSP updated?
BMS: v1048.03 is the latest version? I read that the latest BMS: v1048.04
Maybe I’m wrong and got something mixed up.
Thanks for the answer.
Вам должны прислать апдейт ,через приложение ,обновите
SN: AC180P2352000809378
DSP version 2088.03
Dear, @BLUETTI_CARE Could you please share the latest firmware?
The same problem in UPS mode. Station randomly switches off as well.
Thank you.
AC180P
SN: 2428001056734
IOT:v9046,01
ARM: 2125,02
DSP: 2126.02
BMS: 1048.03
I have the same problem with the UPS mode: device is turned off when grid is down
AC180P2428001487928
IOT v9046,01
ARM v2125,02
DSP v2126,02
BMS v1048,03
I got same situation as @okyesanap
also station didn’t drain more then 260w from grid when charging in silent mode
AC180P2428001817445
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
@BLUETTI_CARE please help
Hello
Please send a firmware update to my device. I have the same problem (AC turns off randomly). Thank you!
Model: AC180P2428001564690
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi @Sergey83, In response to your feedback, we have pushed another version of the DSP v2126.04 for you.
To differentiate between the two firmware versions, we have temporarily renamed it DSP v2126.99. Please proceed with the upgrade, and notify us once it is done so we can remove the upgrade notification.
Please let us know if the new DSP version resolves the issue.
Hello.
New firmware for DSP - 2126.99 has become available. The update is successful up to 100%. In the previous version 2126.04, the TV turned off after 4-5 times after the network was disconnected. With version 2126.99, it turns off immediately. The problem with unstable operation of the UPS has not been solved, unfortunately. In UPS mode, when the network is disconnected, the TV turns off, but the station does not turn off. After some time, the TV turns on from the battery.
Model: Bluetti AC180P
SN: 2428000542814
IoT: v9046.01
ARM: v2125.02
DSP: v2126.04
BMS: v1048.03
Привет, @RuHuR. Мы рекомендуем 1 солнечную панель PV350 или 2 шт. MP200 последовательно.
Обратите внимание, что каждое устройство имеет определенный диапазон входного напряжения PV, общее напряжение холостого хода солнечных панелей не может превышать максимальное напряжение и не может быть ниже минимального напряжения.
Входное напряжение солнечной батареи AC180P составляет VOC 12-60V. Ваша солнечная панель должна соответствовать критериям.
Между тем, пожалуйста, не подключайте разные солнечные панели для использования. Поскольку напряжение холостого хода отличается. Более высокое сгорит, чем более низкое.
Hi @Saulus, In this post, we are only addressing the issue of the AC180P automatically shutting down after fully charging in UPS mode. If the problem is resolved after upgrading the DSP, please let us know your feedback. Thank you for your cooperation.
If your AC180P doesn’t have this issue, there’s no need to upgrade the BMS or other firmware.
Hello.
Yes, the problem of the station turning off when fully charged has been solved. The station does not turn off. Thank you.
Hi @BLUETTI_CARE,
I would like to request once again to register my request for a firmware update for my AC180P. There hasn’t been an update since 30.08.2024. The current parameters of my device are as follows:
AC180P2352000405124
ARM v2089.03
DSP v2088.03
BMS v1039.01
The issue is as follows: The device is used as a backup power source. After charging and operating in standby mode (the device is connected to an external power source and fully charged), the AC output turns off after a few hours. Therefore, when the external power goes out, the unit does not provide backup power through the AC output.
Thanks.
Hello @BLUETTI_CARE
today I received DSP update, after installing and some tests, seems, UPS mode works normally.
Thanks a lot for the help!
