Hello @BLUETTI_CARE Please send a firmware update to my device.
Model:AC180P
AC180P2352001400814
ARM v2089.03
DSP v2088.03
BMS v1039.01
Thank you!
Model:AC180P
AC180P2352001400814
ARM v2089.03
DSP v2088.03
BMS v1039.01
Thank you!
Hello, @BLUETTI_CARE My brand new ac180p does not switch to the battery, but turns off when there is no current in the power grid. Eco mode - OFF but UPS mode doesn’t work. Could you please send me a new firmware with the fix? Thank you
AC180P2428001276176
ARM v2125.02
DSP v2126.02
BMS v1048.03
AC180P2428001443146
IOT v9046,01
ARM v2125,02
DSP v2126,02
BSM v1048,03
Hello! @BLUETTI_CARE
I have the same problem with the UPS mode: device is turned off when grid is down.
Please, can you send me the new firmware to my device to fix this issue?
AC180P
SN 2428001572351
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Thanks a lot!
Hi
In UPS mode station turns off randomly
@BLUETTI_CARE please update my station
AC180P
SN: 2428001128767
ARM: 2125.02
DSP: 2126.02
BMS: 1048.03
Thank you
I need your help. I have the same problem with the UPS mode: device is turned off when grid is down.
AC180P2428001403459
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Thank you very much for your help.
I have the same problem. Device turns off randomly when grid is down.
Please, could you send me firmware updates?
AC180P2428000881864
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Thanks a lot!
AC180P2428000095173
IoT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Моя станция отключается при отключении сети. Как мне решить проблему?
v9046.01
v2125.02
v2126.02
v1048.03
ac180p
ac180p2428001334177
I have a same problem
AC180P2428001487928
IOT v9046,01
ARM v2125,02
DSP v2126,02
BMS v1048,03
The update solved the problem with random shutdown of the device. ![]()
Hello.
Today a new DSP firmware v: 2126.04 appeared - I updated it, the problem was not solved, the third time electricity was cut off (imitation), the connected TV turned off and after some time it turned on from the station. During the first two shutdowns the TV did not turn off.
Model: Bluetti AC180P
SN: 2428000542814
IoT: v9046.01
ARM: v2125.02
DSP: v2126.04
BMS: v1048.03
Try to turn electricity on and off several times (at least 3-5 times)
I have the same problem with UPS mode: the device turns off when the network is disconnected while the battery is fully charged.
@BLUETTI_CARE please can you send me the new DSP firmware v2088.04 for my device to fix this issue? There are currently no updates available for my device (
AC180P2427000073795
IoT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
I have the same problem with the UPS: it turns off when the network is disconnected.
Please send a new firmware for my device
SN: 2428001392174
IoT: v9046.01
ARM: v2125.02
DSP: v2126.02
BMS: v1048.03
Thank you very much!
Hi, @BLUETTI_CARE
Have the same issue on the latest firmware: when no load in UPS mode station turns off in case of external grid outage.
Please send me the new firmware update
AC180P
SN: 2427000020421
IoT v9046.01
ARM v2125,02
DSP v2126,02
BSM v1048,03
Also, does anyone know, why such updates are sent in manual mode by IT department?
Thank you in advance!
I have the same problem: it randomly turns off when the grid disconnects in UPS mode. Please, send my upgrade package. My device info:
SN AC180P2428001340771
ARM V2125.02
DSP V2126.02
BMS v1048.03
S/N AC180P2428000054492
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Hello! Sometimes when the grid cuts off the AC180P turns off at 100% battery. So UPS mode works unstable. Can I get an updated firmware to fix this issue? Please help with this problem.
AC180P23335001432436
ARM v2089.02
DSP v2088.02
please send me new firmware
Hi
The same problem in UPS mode. Station randomly switches off as well.
@BLUETTI_CARE Could you please share the latest firmware?
AC180P
SN: 2427000006505
ARM: 2125.02
DSP: 2126.02
BMS: 1048.03
