I have the same problem. When at 100% battery the station shut downs by itself after some time (ECO is off).
@BLUETTI_CARE Could you please also push this firmware to me?
AC180P2428000311652
ARM 2125.02
DSP 2126.02
BMS 1048.03
AC180P2352001353382
ARM v2089,03
DSP v2088,04
BMS v1039,01
After the update, the vetelator does not turn on in charging station mode
Help.
After firmware, the fan won’t turn on.
Hello I have same issue with shutdowns Could you send firmware update to me?
AC180P2336000027924
ARM v2089.03
DSP v2088.03
BMS v1039.01
Hello, I have same problem with UPS mode.
Can I request the latest software update?
AC180P2428001431609
ARM 2125.02
DSP 2126.02
BMS 1048.03
AC180P2348001090430
ARM 2089.03
DSP 2088.03
BMS 1039.01
Exactly the same problem with my fresh new (only two days) AC180P.
Shutdown occurs only at 100% SoC but sometimes it is seemingly at random, without grid power loss.
Setting sleep timer to never does not resolve the problem. ECO mode is off. No alert/error messages are provided through the app.
IOT 9046,01
ARM 2125,02
DSP 2126,02
BMS 1048,03
Serial number
AC180P2427000044490
Can you help me, please?
AC180P2428001834699
IOT 9046.01
ARM 2125.02
DSP 2126.02
BMS 1048.03
Доброго дня @BLUETTI_CARE
В мене тех вимикається станція , яка заряджена на 100%, після вимкнення світла. Можете меня теж вислати нову прошивку?
AC180P2428001554442
ARM: 2125.02
DSP: 2126.02
BMS: 1048.03
Дякую!
Доброго дня 26.07.2024. просил вас прислать обновление на мою станцию АС180Р2352000501130 ARM v2089.03 DSP v2088.02 BMS v1039.01 проблема с выключением станции после отключения электричества если станция заряжена на 100%. Обновление до сих пор не получил.
Hello! Could you please send me the latest firmware for ac180p. Thank you!
AC1802422001008710
ARM v2124.02
DSP v2126.02
BMS v1052.02
Hello everyone, for the customers who have already provided their SN codes and DSP information, we have applied to upgrade your DSP to our IT department. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Hi @KovaLover, if you want to upgrade your firmware, please let us know your AC180P’s SN code and DSP information, then we will push it soon.
AC180P2427000017045
IoT: v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Hi! Unfortunately, I have the same problem
SN: AC180P2428000981685
IoT: v9046.01
ARM: v2125.02
DSP: v2126.02
BMS: v1048.03
Hello! @BLUETTI_CARE
When at 100% battery the station shut downs by itself after some time.
Turns off randomly in UPS mode.
Could you please share the updated firmware on my device? Thanks in advance!
AC180P2428000368526
IOT v9046.01
ARM 2125.02
DSP 2126.02
BMS 1048.03
При 100% заряде батареи станция сама по себе через некоторое время выключается.
Выключается произвольно в режиме ИБП.
Не могли бы вы поделиться обновленной прошивкой на моем устройстве? Заранее спасибо!
AC180P2424010117038
ARM 2089.02
DSP 2088.02
Hi
AC180P2428000509978
IoT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
SN 2428000509978
Model: AC180P
SN: AC180P2344000819684
ARM: v2089,02->v2089,03
DSP: v2088,02->v2088,03
BMS: v1039,01
