AC180P2428001042907
IoT: v9046.01
ARM: v2125.02
DSP: v2126.02
BMS: v1048.03
Привіт. Прошу оновлення для стабільної роботи станції AC180P в режимі безперебійного джерела живлення
S/N 2428000215784
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Hello!
Having:
AC180P2428001590335
IoT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Eco mode is off.
Sometimes when the grid cuts off AC180P will turn off having some load connected (even a router or a lamp). I thought it’s a hardware issue, but after a few attempts - it stays ON when i cut off the grid manually. So looks like a firmware issue.
Bluetti might turn off even if it’s 100% full and some lamp (15W) is connected, then i manually turn off the grid and AC on Bluetti turns off.
Hi @BLUETTI_CARE
Sorry for bothering but it seems I have the same problem on the latest firmware. Could u help me please ?
Sn AC180P2428000165186
Thanks in advance
UPS mode works unstable, plz help with this problem.
AC180P2427000105644
lOT v9046.01
ARM v2125.02
DSP v2126.02
BMS V1048.03
Hello! I’m going to use my BLUETTI as UPS. Please send a firmware update to my device. Thank you!
Model: AC180P
SN: AC180P2424010070218
ARM: v2089,03
DSP: v2088,03
BMS: v1039,01
Greetings, please send me an update for stable operation of the station in UPS mode (serial number AC180P2428000194459, ARM v2125.02 DSP V2126.02). Thank you.
Hello! @BLUETTI_CARE
Model: AC180P
SN: AC180P2428001343803
IOT: v9046,01
ARM: v2125,02
DSP: v2126,02
BMS: v1048,03
Dear @BLUETTI_CARE, I am experiencing an issue where my AC180P unit randomly turns off while in UPS mode. Could you please assist with upgrading the firmware to the latest version to address this problem?
AC180P2352000405124
ARM v2089.03
DSP v2088.03
BMS v1039.01
Thank you for your support.
Hi @alexvovk0604, We have pushed the original firmware DSP v2088.03 to your AC180P as per your request.
You can roll back to the original firmware via the app.
I hope it does help.
Hi @VLADIMIRSKIRDA1, We wonder if you received the new DSP v2088.03, please upgrade it according to the screenshot below.
Hi @Kvytsen, Can you try to upgrade the DSP v2088.03?
Please click the new firmware to upgrade, I think you can fix it directly.
If the DSP v2088.03 does not work, we will upgrade to the next version.
When at 100% battery, my station shuts down by itself after some time.
Turns off randomly in UPS mode.
Could you please share the updated firmware on my device? Thanks in advance!
SN AC180P2428000421832
IOT v9046.01
ARM v2125.02
DSP v2126.02
BSM v1048.03
I have the same problem on my device:
AC1802422002050399
IOT v9046,01
ARM v2124,02
DSP v2126,02
BMS v1052,02
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2352000809378
Hi @KovaLover, can you click the blue Upgrade icon to upgrade the DSP to v2088.03?
Hi @Pletenets, If the AC180P shuts down randomly after being fully charged in UPS mode, it needs a DSP upgrade to resolve the issue.
We found that your DSP is already updated to the latest version. Is your AC180P working normally? If everything is functioning properly, no further action is needed.
I have updated the firmware (DSP 2126.02 > 2126.04) and the UPS is now working well .
Thanks.
Hi @VitaliyL, if you want to upgrade your firmware, please let us know your AC180P’s current DSP version, and then we will push it soon.
Hi @er13, thank you for letting us know! I am glad to hear that, I will share this good news with our engineer. ![]()
