AC180P turns off randomly
Hello @BLUETTI_CARE
I’m going to use my BLUETTI as UPS. Please send a firmware update to my device. Thank you!
Model: AC180P
SN: AC180P2344000819684
ARM: v2089,02->v2089,03
DSP: v2088,02->v2088,03
BMS: v1039,01
Hey, @BLUETTI_CARE
Could you please share the updated firmware on my device? Thanks in advance!
AC180P2428000666981
ARM V2125.02
DSP v2126.02
BMS v1048.03
Hi @Iryna, @alexvovk0604, @Tokugava and @Mr_Alexander, I have applied to upgrade your DSP to our IT department. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Hi @KovaLover, can you try to upgrade the DSP v2088.03?
Please click the new firmware to upgrade, I think you can fix it directly.
If the DSP v2088.03 does not work, we will upgrade to the next version.
Hi @b1smu_th, I have applied to upgrade your DSP to our IT department. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
AC180P2427000090887
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Hi! @BLUETTI_CARE
AC180P2428000444986
IOT v9046.01
ARM 2125.02
DSP 2126.02
BMS 1048.03
Hello @BLUETTI_CARE
Please send a firmware update to my device. I have the same problem with my AC180P (turns off randomly in UPS mode). Thank you!
S/N AC180P2428000227152
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Please update my power station (in UPS mode it turned off when power from the grid was lost)
AC180P2352001568405
ARM v2089,03
DSP v2088,02-v2088,03
BMS v1039,01
Hi, I have the same problem.
when at 100% battery and losing power from the grid the station shut downs by itself. Please send or push this new firmware update to me.
AC180P2428000167964
IoT 9046.01
ARM 2125.02
DSP 2126.02
BMS 1048.03
Hello!
S/N AC180P2352001017992
ARM v2089.03
DSP v2088.03
BMS v1039.01
Hi, please send update to my device (in UPS mode it turned off when power from the grid was lost)
S/N AC18OP2427000112990
IOT v9046.01
ARM 2125.02
DSP 2126.02
BMS 1048.03
Hello @BLUETTI_CARE
S/N AC180P2428000478679
IOT v9046.01
ARM v2125.02
DSP v2126.02
BMS v1048.03
Hi! Please send a firmware update to my device.
AC180P
SN 2352001001031
ARM V2089.03
DSP v2088.03
BMS v1039.01
Thank!
AC180P2352001568405
ARM v2089,03
BMS v1039,01
У мене та ж проблема. При 100% батареї станція вимикається сама через деякий час (ECO вимкнено).
@BLUETTI_CAREНе могли б ви також надіслати мені це оновлення?
AC180P2335001500238
ARM
v2089.03
DSP
v2088.03
BMS
v1039.01
I have the same problem. With 100% battery, the station switches itself off after about an hour (ECO is switched off).
@BLUETTI_CARE Could you please send me an update as well?
AC180P2335001500238
ARM v2089.03
DSP v2088.03
BMS v1039.01
I don’t have an update button in the app.
Dobry day. After the whitewash, the fan stopped turning on. Can I return the old firmware?
Hello, I have the same problem as described; the new AC180P has been turned off at night with a refrigerator connected, and DC and AC ECO modes were previously turned off; please send a proper firmware update, thank you.
AC180P2428000239277
IoT: 9046.01
ARM: 2125.02
DSP: 2126.02
BMS: 1048.03
