AC180P turns off randomly
Hi @funnydie, Now I have applied to upgrade your system to our IT department. They will push the latest version of DSP to your machine in 24 hours.
Please upgrade it tomorrow. Please do not load any device when upgrading it.
Hi @Vladism, Now I have applied to upgrade your system to our IT department. They will push the latest version of DSP to your machine in 24 hours.
Здравствуйте. Вышлите мне пожалуйста последнюю версию прошивки.
AC180P2342001309084
ARM: v2089,3
DSP: v2088,03
BMS: v1039,01
Dear @BLUETTI_CARE
Please update my power station.
AC180P2352000119582
ARM version v2089.03
DSP version v2088.03
BMS version v1039.01
Hello @BLUETTI_CARE
I have the same problem.
AC180P2342001047218
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hi @RuHuR and @Jeka, Now I have applied to upgrade your system to our IT department. They will push the new DSP to your machine in 12 hours.
Please upgrade the firmware according to the attachment tomorrow. Please do not load any device when upgrading it.
Hi @Zvitman, We’ve already pushed batch DSP version 2088.03 to your device. Could you please log in to the app and try upgrading directly? This should help resolve the issue.
Hello! Since my first post (originally DSP v2088.02), I installed DSP v2088.03. After that, I tested the device again, and it randomly turned off after 6 hours of operation (ECO disabled). Please give me DSP v2088.04. I’ll test it and report back. Thank you.
Hi @Zvitman, Now I have applied to upgrade your system to our IT department. They will push the new DSP to your machine in 12 hours.
Hi! It’s been a while. So, should we expect the fan issue to be resolved by this year’s upcoming updates, ideally by October? Thanks
Пожалуйста, отправьте обновление прошивки на мое устройство.
Модель: AC180P
SN AC180P2335000973481
ARM: v2089.03
DSP: v2088.03
BMS: v1039.01
Пришлите новую прошивку, пожалуйста
AC180P2349002089178
ARM 2089.02
DSP 2088.02
BMS 1039.01
hi, you forgot to send me an update))
Hello! Tested for 2 days - there were no random shutdowns. Thank you!
Please send a firmware update to my device. I have the same problem with my AC180P (turns off randomly in UPS mode). Thank you!
AC180P
s/n 2349002467086
ARM v2089.03
DSP v2088.03
BMS v1039.01
@BLUETTI_CARE I am experiencing this issue with my AC180, the ups does not work when the grid is disconnected at 100% after being used for a while with battery fully charged.
AC180
AC1802330000704868
ARM V2074.07
DSP v2078.06
BMS v1033.12
Hi @tkachenko and @emmanuel, Now I have applied to upgrade your DSP to our IT department. They will push the latest version of firmware to your machine in 12 hours.
@BLUETTI_CARE I kindly ask to apply my device for the firmware upgrade, in order to fix the above mentioned issue.
The seller guided me towards these forums to fix the “100% charge UPS mode unexpected device shutdown on grid outage issue”.
My device’s tech data as follows:
AC180P2352000852994
ARM v2089.03
DSP v2088.02 → v2088.03 (as indicated in the app Version section, never pressed any update button, so must be .02)
BMS v1039.01
Hi @g_man, can you try to upgrade the DSP v2088.03? Please click the new firmware to upgrade, I think you can fix it directly.
If the DSP v2088.03 does not work, we will upgrade to the next version.
@BLUETTI_CARE I am experiencing issue with my AC180P, the ups does not work when disconnecting the grid or connecting vise versa, it can’t switch to battery or passthrough instantly as a result i loose ac for a second. Tried disabling grid self-adaptation. didn’t helped
AC180P
AC180P2424010245847
ARM V2125.02
DSP v2126.02
BMS v1048.03
