Hello @BLUETTI_CARE
Please send a firmware update to my device. I have the same problem with my AC180P (turns off randomly). Thank you!
AC180P2349000386621
ARM-v2089.02
DSP-v2088.02
BMS-v1039.01
Hello @BLUETTI_CARE
AC180P2349000386621
ARM-v2089.02
DSP-v2088.02
BMS-v1039.01
Hello, I have the same problem as well. Device turns off randomly + doesn’t work as an UPS when electricity in the apartment shuts down, could you please send me a new firmware with the fix? Thank you
SN: AC180P2335001627649
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Same thing for me, not always, but pretty often my device shuts down as soon as electricity goes down. Using it as UPS, and that’s frustrating! What’s the cure @BLUETTI_CARE?
SN: AC180P2349000369243
I have the same problem. When at 100% battery the station shut downs by itself after some time
@BLUETTI_CARE Could you please also push this firmware to me?
AC180P2341000160863
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello, @BLUETTI_CARE. Same problem here. Could you please send me firmware update?
AC180P2349000017097
ARM 2089.02
DSP 2088.02
BMS 1039.01
P. S. BTW you have loads of similar requests, everyone needs to ask the update manually. Any reasons, why not include this update into Bluetti app, so that everyone could update independently?
Hi @BLUETTI_CARE. I have a similar problem with AC180P
It randomly shuts down when starting to charge the fridge. It also shuts down whenever it disconnects from the grid. No errors were displayed. The battery is 100% charged. Could you please send the firmware update?
AC180P2410000089987
ARM v2125,02
DSP v2126,02
BMS v1048,03
Hello BLUETTI
Same problem here. Can you please push new firmware version to me?
Ac180p2349001259264
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Ні.
I have the same issue as others with my AC180P unexpectedly shutting down in UPS mode when it shouldn’t.
Please sent me the update which will resolve this issue. Thanks.
S/N AC180P2335001841161
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello @BLUETTI_CARE Please send a firmware update to my device. the same problem. random shutdown in UPS mode.
AC180P2344000805161
I need that update too
AC180P2341000868351
ARM
v2089.02
DSP
v2088.02
Hello @BLUETTI_CARE
The same problem when working in UPS mode. Please send me the new firmware for my device:
Model: AC180P
SN: 2349000192450
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
Hello!
Please send a firmware update to my device. Thank you!
AC180P2352000149900
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello @BLUETTI_CARE
AC180P2335001363447
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello @BLUETTI_CARE
AC180P2349001566263
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P2349000408215
ARM
v2089.02
DSP
v2088.02
BMS
1039.01
Hello everyone, for customers above who have already provided the SN code and DSP version, I have requested the new DSP v2088.04 to be pushed. This will be completed within 24 hours. Please check if you received the new DSP v2088.04 in your Bluetti APP, upgrade the firmware, and test if the issue of the AC180 is resolved. Please do not load any device when upgrading it.
I cannot switch charging mode for my both devices AC180P and AC70P from application.
Seems this happens after latest application update.
That is not so critical for AC70P as the charging mode can be selected at AC70P front panel.
This is not the case for AC180. You can switch AC180P charging mode via application only which is not working now.
Will you please advise ?
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
АС180P2344004149793
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi @Ryslanline , We offer a custom firmware DSP v2088.04 for the AC180P to customers in regions with unstable power grids. If you have already upgraded to the regular version of DSP v2088.04, we will temporarily rename this custom firmware to DSP v2088.99. If you haven’t upgraded to the regular version of DSP v2088.04 yet, we will directly push this upgrade to you. Please help us test the performance of this custom DSP to see if it can assist with AC charging in unstable power grid environments. We are waiting for your feedback.
