Hi,
Please, send me firmware update
ARM
v2089.02
DSP
v2088.02
BMS
v1039.01
Bluetti AC180P
AC180P2342000652195
Hi,
ARM
v2089.02
DSP
v2088.02
BMS
v1039.01
Bluetti AC180P
AC180P2342000652195
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2335000667608
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hello, I have same problem with UPS mode.
Can I request the latest software update?
SN: AC180P2335001465423
DSP: v2088.02
I have the same problem, could you please sent me a new firmware.
AC180P2341000211227
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
I have the same problem, please send me firmware update.
AC180P2335001656337
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, I did not receive the firmware update…
Could you send it to me again?
AC180P2341000286095
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello, I have the same problem, station turn off in UPS mode. Please share firmware to my device AC180P2342000088752
AC180P2349000408215
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello!
I have the same problem.
The power station AC180P unexpectedly turns off while works as ups even though Eco mode is turned off.
AC180P2342000019420
ARM v2089,02
DSP v2088,02
BMS v1039,01
After greed disconnects, the station shut downs by itself. UPS does now work sometimes. Problem like others in this discussion.
@BLUETTI_CARE Can you please also push new firmware to me?
AC180P2349001089325
ARM 2089.02
DSP 2088.02
BMS 1039.01
The screen at the charging station is glitched, it works on its own, AC and DC are also displayed in the application as needed, the only thing is that the screen is glitched, maybe there is a new firmware, please send it to me, it can help solve my problem.
AC180P2349000408215
ARM 2089.02
DSP 2088.02
BMS 1039.01
Have the same error. Can’t change the charging mode. When I chose silent or turbo it doesn’t change at all, staying at standard. Yesterday everything worked properly. Would you please push me the firm update please.
AC180P2349001581377
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello! Can you fix me the same problem while i use in UPS mode
AC180P2349002027669
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, I have a new problem: there is no way to change the charging mode. Yesterday, before going to bed, I started charging the station in silent mode, but already today I cannot choose another charging mode. Eco mode is disabled, grid self-adaptation on/off does not give results. Help @BLUETTI_CARE
AC180P2332001456141
ARM: v2089.02
DSP: v2088.04
BMS: v1039.01
Hi
I received an update for my AC180P and now the DSP version is v2088.4. While of two days, not a single shutdown and it is good. But I found a new problem. I can’t switch the charging mode, it always stays in Silent. Reinstalling the APP did not help. What should help me be able to change the charge mode? This mode is very important to me.
АС180Р2348000984667
AC180P2341000159163
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hello @BLUETTI_CARE. I have the same issue with UPS mode. AC180P shutting down on electricity outage. Eco mode - OFF. Please send firmware update to my device.
AC180P2349001965092
ARM: V2089.02
DSP: V2088.02
BMS: V1039.01
Thank you!
Hello @BLUETTI_CARE!
I also have a problem with my Bluetti AC180P.
When the battery is 100% charged, the station turns itself off after a while.
Please send me the updated firmware.
AC180P2332001315982
AWP v2089.02
DSP v2088. 02
BMS v1039.01
Здравствуйте есть проблема с работой станции как ДБЖ прошу вас выслать прошивку для корректной работы станции АС180Р2335001785733
ARM v2089,02
DSP v2088,02
BMS v1039,01
Hi @BLUETTI_CARE,
I have the same issue, could you please push this firmware to my device as well?
AC180P2344002034292
ARM 2089.02
DSP 2088.02
BMS 1039.01
