AC180P turns off randomly
Hello
Now have same issue with shutdowns at 99%
Could you send firmware update 04 to me?
S/N AC180P2349001406843
ARM v2089.02
DSP v2088.03
BMS v1039.01
Could you please send the new update to avoid ups function shutdown for
SN AC180P2344004204470
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thank you in advance
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2344000553103
ARM: v2089.02
DSP: v2088.02
BMS: V1039.01
AC180P2344000656213
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
AC180P2344000543118
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello, @BLUETTI_CARE.
I have same issue with exactly the same symptoms.
Not working as UPS when 100% charged.
Could you please provide firmware update also for me?
S/N AC180P2332001437625
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi! @BLUETTI_CARE
I have the same problem. Please, send me a new firmware to fix it)
AC180P2349001278821
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please, help me to fix this issue.
Thanks!
AC180P2344000660376
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE
Please send a firmware update to my device. I have the same problem (AC turns off randomly). Thank you!
Model: AC180P
SN AC180P2344004019584
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Привіт,у мене проблема з UPC.Не могли б ви надіслати мені оновлення мікропрограми?
AC180P2341000786197
ARM v2089,02
DSP v2088,02
Send me the update, please!
AC180P2341000928813
ARM v2089.02
DSP v2088.02
BMS v1039.01
@BLUETTI_CARE
when at 100% battery and losing power from the grid the station shut downs by itself. please send me a new firmware
AC180P2344000855945
ARM: 2089.02
DSP: 2088.02
BMS 1039.01
AC180P2344000542651
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
AC180P2344000668322
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
AC180P2344000902519
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Can you send me an update for my device?
AC180P2348001072636
SN2348001072636
ARM v2089.02
DSP v2088.02
BMS v1039.01
Same symptoms here. No shutdown at 100%, but shuts down at 99% when connected to the grid with AC load. Both ECO off. Please push DSP 2088.04 to me as well.
AC180P2332001219563
S/N 2332001219563
ARM 2089,02
DSP 2088,02
BMS 1039,01
@BLUETTI_CARE @BLUETTI
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2349001976816
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
@BLUETTI_CARE
I have same issues
Can you push the update to me please
SN AC180P2342000499686
ARM v2089.02
DSP v2088.02
Hi @yuriy1975h Thank you for letting us know, I have reported it to the R&D department.
