Hi @VSM , In response to the fan issue you mentioned earlier, our R&D team has specifically created a new firmware and pushed it to your machine. Please upgrade and test it, and let us know the results. We hope this helps.
Hello @BLUETTI_CARE
Please send a firmware update to my device. I have the same problem (AC turns off randomly). Thank you!
Model: AC180P
SN AC180P2349001371622
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2341000752045
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Привет
Та же проблема в режиме ИБП. При отключении электричества станция тоже произвольно отключается.Не могли бы вы поделиться последней версией прошивки?
AC180P2344000965566
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Спасибо
Hello, @BLUETTI_CARE.
I have same issue with exactly the same symptoms.
Not working as UPS when 100% charged.
Could you please provide firmware update also for me?
S/N AC180P2335000613811
ARM v2089.02
DSP v2088.02
BMS v1039.01
@BLUETTI_CARE, Hello. Please send an update to my device.
Serial: AC180P2335001727897
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thanks.
We should migrate to separated tread with this issue ![]()
But here is my serial number. Expecting for new firmware with fix. Thx a lot. @BLUETTI_CARE
AC180P2349000731658
ARM: 2089.02
DSP: 2088.04
BMS: 1039.01
В Мене така ж сама проблема
Прошу направити оновлення
AC180P2335000751095
ARM v2089.02
DSP v2088.02.
BMS v1039.01
Привіт,у мене проблема з відключенням.Не могли б ви надіслати мені оновлення мікропрограми?
AC180P2344003113958
ARM v2089.02
DSP v2088.02.
BMS v1039.01
Hi! You guys are awesome, but I don’t think it has been pushed yet
Same for BMS, but I’ll wait if it takes time.
My s/n just in case: AC180P2349002052438
Can you send me an update for my device? when the device is turned on in UPS mode, if there is a power turns off, the device turns off too.
AC180P2335001412492
ARM v.2089.02
DSP v.2088.02
BMS v.1039.01
tnks
Будь ласка надішліть і мені нову прошивку
AC180P2349001909688
ARM v2089,02
DSP v2088,02
BMS v1039,01
AC180P2348001072636
ARM v2089.02
DSP v2088.02
BMS 1039.01
Новий Bluetti AC180P працює як ДБЖ для холодильника 6970991292668;RVPOWERB2B-231 025-0001-299;POWERB2B-P-AC180 P-EU-GY-BL-010; Через кілька годин (приблизно 4) він просто повністю вимикається. Режим ECO вимкнено. Заряжено 100%.
AC180P2344000548945
ARM v2089.02
DSP v2088.02
BMS v1039.01
Прошу вислати останнє оновлення. З повагою petrucsha@gmail.com
Hello! Please send me the new firmware version. Thank you!
S/N AC180P2341000289657
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P2344004110470
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, the device shuts down when the power is turned off, which does not allow me to use it in UPS mode. Could you please send me the latest firmware?
sn: AC180P2341000354602
ARM v2089,02
DSP v2088,02
BMS v1039,01
Hi @BLUETTI_CARE ! Can you please push new firmware to my machine as well since I have the same problem with fans that VSM mentioned. I described it in one of my posts above.
Thank you in advance!
AC180P2344004182896
ARM v2089.02
DSP v2088.04
BMS v1039.01
Привіт. Скиньте будь ласка оновлення прошивки (2088,04) щоб не вимикалась
Model - AC180P
SN - 2349002110358
ARM версія v2089,02
версія DSP v2088,02
BMS версія v. 1039,01
Hello I still didn’t got the new update for my station
Can you send it to me please
SN AC180P2342000499686
ARM v2089.02
DSP v2088.02
Hi! I have the same problem.
Could you please push this new firmware to me?
AC180P2344004192089
ARM v2089.02
DSP v2088.02
BMS v1039.01
