@BLUETTI_CARE
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2342000499686
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
@BLUETTI_CARE
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hi, could you push new firmware to me, please? Thanks!
AC180P2344003115908
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
AC180P2349001909688
ARM v2089,02
DSP v2088,02
BMS v1039,01
The ac180p turns off when operating in UPS mode, an update is needed. Thank you.
AC180P2342000274156
ARM version v2089.02
DSP version v2088.02
BMS version v1039.01
@BLUETTI_CARE @BLUETTI
SN: AC180P2349001976816
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hi, I have the same problem. Could you please send me an update?
SN: AC180P2341000769523
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thanks!
Hello @BLUETTI_CARE Please send an update to my device.
Serial: AC180P2335001727897
ARM v2089.02
DSP v2088.02
BMS v1039.01
SN: AC180P2349002093124
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Hello @BLUETTI_CARE! I have the same problem. βwhen at 100% battery and losing power from the grid the station shut downs by itself (sometimes).β Please help me. AC180P2349001583695 ARM: v2089,02 DSP: v2088,02 BMS: v1039,01
Hi, I have the same issue, AC180P turns off in UPS mode (ECO off). Could you please send me a new firmware with the fix? Thank you
SN - AC180P2335001482098
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Hello.
A similar issue has occurred in UPS mode. When the power is disconnected, the station also shuts down randomly.
@BLUETTI_CARE, could you please share the latest firmware version?
AC180P2349000533052
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
@BLUETTI_CARE , after updating the firmware to v2088.04, somehow the coolers of the station began to work. At a minimum load of up to 100 watts, they turn on and make a lot of noise, which was not the case before.
Tnanx, seems that after upgrade ups mode is working
Could you please send firmware update for my station AC180P. I have the same problem with turn off randomly in UPS-mode.
SN: AC180P2349000905056
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE,
I have two devices AC180P and they both have a similar issue in UPS mode.
Device #1
Device #2
Could you please share with me the latest firmware?
Thanks!
@BLUETTI_CARE Sorry, i send wrong serial number -
AC180P2342000899093
Can you please send new firmware to me?
Hi @BLUETTI_CARE ,
Could you please send me firmware update for my power station?
I have same issues in UPS mode.
SN AC180P2335001869782
ARM: v2089,02
DSP: v2088,02
BMS: v1039.01
Thanks in advance!
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2344000663798
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
AC180P2344000669819
ARM: v2089.02
DSP: v2088.02
BMS: V1039.01
Hi
The same problem in UPS mode. When electricity is turned off station randomly switches off as well.
@BLUETTI_CARE Could you please share the latest firmware?
AC180P2335001481076
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
