Hi @BLUETTI_CARE , could you provide me a firmware update for my AC180P?
AC180P2344004308490
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2344000776687
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Hi @BLUETTI_CARE,
I have the same issue, could you please push this firmware to my device as well?
As I understood it correctly after update 2089.04 I will have the same issue with infinity working fans
as @VSM has.
AC180P2341000861617
ARM 2089.02
DSP 2088.02
BMS 1039.01
SN: AC180P2335001568891
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Hello! @BLUETTI_CARE
SN: AC180P2342000271236
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
Not exactly, I had it with 2088.02, and the new firmware (2088.04) didn’t fix it. Someone tagged me above with the same issue so it’s not a product defect and everyone most likely has it. Probably no one reported it because no one used this station as a 24/7 UPS for their home network which consumes <15-30 watts before.
Hi! @BLUETTI_CARE
Could you please push this new firmware to me?
AC180P2344003076441
ARM 2089.02
DSP 2088.02
BMS 1039.01
Привет@BLUETTI_CARE,
Та же проблема здесь. Не могли бы вы также прошить это устройство?
AC180P2332001453199
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hi, I have the same issue. Could you please send me a new firmware with the fix? Thank you!
SN: AC180P2344004114829
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hello @BLUETTI_CARE !
Please send a firmware update to my device. I have the same problem with my AC180P (turns off randomly). Thank you!
Model: AC180P
SN: AC180P2349001668657
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
Hello!
Please send a firmware update to my device. Thank you!
SN: AC180P2344000697887
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
SN: AC180P2344004360004
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hello @BLUETTI_CARE
I have turn off issue too. Please, share the updated firmware to my device too
Model:AC180P
AC180P2344003124329
ARM v2089.02
DSP v2088,02
BMS v1039.01
Hello @BLUETTI_CARE
Model: AC180P
S/N: 2348001087680
ARM: v2089.02
DSP: v2088.02
BSM: v1039.01
Thank you!
I’m expecting new firmware too. Thx a lot.
AC180P2342000446616
ARM: v2089.02
DSP: 2088.02
BMS: 1039.01
Здравствуйте.
Возникла похожая проблема в режиме UPS. При отключении электричества станция тоже произвольно выключается.
@BLUETTI_CAREНе могли бы вы поделиться последней версией прошивки?
AC180P2344004358352
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Thank you, the update has arrived - DSP v2088.04
Now my station does not turn off when it is charged to 100%. It was buzzing all night.
The problem with the UPS has been resolved, hurray
Can we now solve the problem so that it turns off when fully charged?
Hi @BLUETTI_CARE!
My AC180P is having an issue with completely shutting off when at full charge and is disconnected. Thus it cannot reliably work as an UPS.
Could you please check if it is possible to solve via a firmware upgrade?
S/N AC180P2349000703859
Arm v2089,02
Dsp v2088,02
BMS 1039.01
Hi @kag0n , We have initiated the process to unbind for you, which will be completed within 24 hours. Please rebind the machine tomorrow to proceed with the upgrade.
Hi, I have the same problem. Could you please send me an update?
AC180P2349000389186
ARM - v2089.02
DSP - v2088.02
BMS - 1039.01 -
AC180P2349000397576
ARM - v2089.02
DSP - v2088.02
BMS - 1039.01
3)AC200M2244002000457
ARM - v4008.05
DSP - v4005.08
BMS - 1017.03
