Hi! I have the same problem.
Could you please push this new firmware to me?
AC180P2349000834262
ARM v2089.02
DSP v2088.02
BMS v1039.01
I have the same problem. Please, send me a new firmware to fix it.
ACI8OP2332001355052
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please, help me to fix this issue.
Thanks!
Hello @BLUETTI_CARE. I have same problem. Can you please push new firmware version to me?
AC180P2349001432943
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
I use AC60R as a UPS, but when I turn off the lights it often turns off and gives the error Short or overload, Tell me what to do
Добрый день. Появилось информация о том что предвидеться новая прошивка, но возможности установить её нет. Подскажите пожалуйста, когда можно будет установить новую прошивку, чтобы AC180P не отключался при отключении внешнего электроснабжения. Спасибо!
Вот скрин:
Hello @BLUETTI_CARE . Can my AC180P get an update too?
AC180P2332001374293
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
Thank you in advance!
Hello @BLUETTI_CARE. I have same problem. Could you please push new firmware to me?
AC180P2332001221749
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
Hello! Can you fix me the same problem while i use in UPS mode !
AC180P2344000967724
Arm: v2089.02
Dsp: v2088.04
Bms: v1039.01
I didnt get update version
Hello @BLUETTI_CARE Please send a firmware update to my device. Model:AC180P AC180P2349001956629 ARM v2089,02 DSP v2088,02 BMS v1039,01 Thank you!
Hello @BLUETTI_CARE ! I have the same problem.
AC180P2349000578342
ARM 2089.02
DSP 2088.08
BMS 1039.01
Hi @smelnik, Using which model to charge or discharge the AC180P is not important.
Here are some suggestions for storing the unit.
- Never store the battery empty, even for only a few days. LiFePO4 batteries might be unrecoverable if stored empty.
- Storage temperature: 0-40℃. Don’t store the battery in a humid environment. Please keep it away from fire as well.
- The optimal state of charge for long-term storage is 50%.
- The battery will slowly self-discharge over time. The battery should be calibrated every 3-6 months.
- Don’t store the battery on its side. Keep it up straight.
- Don’t stack things on top the unit. Don’t block the fans.
About how to calibrate the battery, please follow the steps below:
- Please discharge all the power (charge AC & DC appliances with the power station till it is out of power and turns off automatically);
- Once the power is 100% fully charged, turn off the machine, and leave it the whole day.
Good day, problem with Ups
S\n AC180P2335001508688
ARM v2089.02
DSP v2088.02
BMS v1039.01
When at 100% battery the station shut downs by itself after some time.
@BLUETTI_CARE Could you please also push this firmware please? Model: AC180P
AC180P2344003061661
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P2332001456141
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello, I have applied to push the new DSP v2088.04 to all AC180 units above mentioned. The update will be completed within 24 hours. Please proceed with the upgrade tomorrow. We hope this will be helpful.
Hello, same problem with UPS mode
s\n AC180P234200899093
ARM v2089.02
DSP v2088.02
BMS v1039.01
