Hello @BLUETTI_CARE !
Please send a firmware update to my device. I have the same problem with my AC180P (turns off randomly). Thank you!
Model: AC180P
SN: 2341000255658
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
Hello @BLUETTI_CARE Please send a firmware update to my device.
Model:AC180P
AC180P2335001001722
ARM v2089,02
DSP v2088,02
BMS v1039,01
Thank you!
Now i can’t charge it. Got issue - low grid voltage. But nothing changed in that term. Also as passthrough it works fine. Nothing from pop-up troubleshooting, didn’t help
Did you get updates new version?
Hello. Kindly provide the new firmware
SN: AC180P2335002001026
ARM: v2089.02
DSP: 2088.02
- The device turns itself off after grid disconnection instead of turning the UPS mode on.
The eco and powerlifting modes are turned off. - Being connected to the grid in a pass-through mode the device randomly discharges down to 99% and then starts charging itself back a 100%.
Thank you in advance.
@BLUETTI_CARE
Please send new version to
Ac180p2349001914654
Hello @BLUETTI_CARE
Have the same issue. Please, share the updated firmware to my device as well.
Model:AC180P
AC180P2344004117614
ARM v2089,02
DSP v2088,02
BMS v1039,01
Hi @BLUETTI_CARE I have the same problem with shutdown
Model: AC180P
AC180P2344000920924
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello @BLUETTI_CARE
I have turn off issue too. Please, share the updated firmware to my device too
Model:AC180P
AC180P2335001102912
ARM v2089.02
DSP v2088,02
BMS v1039.01
Hello @BLUETTI_CARE
Model:AC180P
AC180P2344000973308
ARM v2089.02
DSP v2088,02
BMS v1039.01
Hello @BLUETTI_CARE
Model:AC180P
AC180P2349002102265
ARM v2089,02
DSP v2088,02
BMS v1039,01
Hello!
Please send me the update.
Model: AC180P
AC180P2349000262331
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello there! Please send me an update to my station… I would like to use it as UPS sometimes. ![]()
It’s a very hard times now in Ukraine, so the station like an angel save us. Thank you for your support! ![]()
S/N AC180P2342000672337
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello @BLUETTI_CARE Please send a firmware update to my device. the same problem. random shutdown in UPS mode. Setting sleep timer to never does not resolve the problem. ECO mode is off.
Model: AC180P
AC180P2349001507331
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, I have the same issue.
SN: AC180P2335001938844
ARM v2089.02
DSP v2088.02
BMS v1039.01
Could you please sent the new firmware to my device ?
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2344000851327
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Please provide me the new firmware for my station to work in UPS mode
Model: AC180P
AC180P2349001962598
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi! I have the same problem.
Could you please push this new firmware to me?
AC180P2335001561057
ARM 2089.02
DSP 2088.08
BMS 1039.01
AC18OP2349000039235
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello
Get a similar problem in UPS mode. When electricity is turned off station randomly switches off as well.
@BLUETTI_CARE Could you please share the latest firmware?
AC180P2349001539052
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
