Hello! Can you fix me the same problem while i use in UPS mode !
AC180P2332001072693
Arm: v2089.02
Dsp: v2088.02
Bms: v1039.01
AC180P2332001072693
Arm: v2089.02
Dsp: v2088.02
Bms: v1039.01
Please provide me the new firmware for my station to work in UPS mode
AC180P2335000864851
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
@BLUETTI_CARE Hey, I have the same problem. When at 100% battery and losing power from grid the station sometimes shut downs by itself.
Could you please also push this firmware to me?
AC180P2341000750556
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello! Have the same issue
Please send the update. Thank you in advance.
AC180P2332001075884
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hi, same problem, AC180P turns off in UPS mode (ECO off).
SN - AC180P2332001358921
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Hello @BLUETTI_CARE
SN: AC180P2349000832336
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
Hi, i have the same problem, AC180P turns off in UPS mode. The ECO mode is off.
Please provide me a new firmware for my station to work in UPS mode
SN - AC180P2332001077872
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Hello! I have the same problem - AC180P turns off in UPS mode when 100% charged.
SN - AC180P2344000369924
Hello @BLUETTI_CARE
I have the same problem with my AC180P when I try to use it as UPS for my fridge - it periodically turns off.
Details about my bluetti device:
S/N AC180P2335001745345
FW versions:
ARM v2089.02
DSP v2088.02
BMS v1039.01
Pls help me to solve this issue. By fw update or anything else.
Thanks!
SN - AC180P2341000737905
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Dear @BLUETTI_CARE , could you please push the new update to me as well? I have the same problem with UPS mode.
Device AC180P2341000258871
ARM Version: v2089.02
DSP Version: v2088.02
BMS v1039.01
Hey @BLUETTI_CARE ! I made the post on Saturday but haven’t received the update yet. Could you please provide it bit faster?
Thank you
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2341000783798
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
Greetings,got totally same issue. Shut downs by itself, and doesn’t work as UPS
AC180P2344000968453
ARM v2089,02
DCP v2088.02
BMS v1039,01
The above requests will be processed in 24 hours.
You should have received it, please check again.
Good afternoon @BLUETTI_CARE
Thank you for the firmware that fixed my problem.
Can you tell me in which mode I should periodically discharge the station to ensure the battery operates in optimal condition, does not deteriorate, and does not lose its capacity when used as a UPS?
I read somewhere that it is beneficial to discharge the station to 20% once a month, followed by charging it to 80-100%. Is this correct?
Hi @BLUETTI_CARE
Have the same described problem and need new firmware
My SN: AC180P2349001085835
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Thank you
Please send a firmware update to my device. my AC180P turns off randomly
Model: AC180P
SN 2332001397883
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
