Please send a firmware update to my device. my AC180P turns off randomly
Model: AC180P
AC180P2341000640687
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
@BLUETTI_CARE
Five days ago, I received DPS 2088.04 from you.
During this time, I experienced several disconnections when the computer was under load. The station no longer shut down along with the centralized power outage.
I will continue to monitor it.
Shutdown occurs only at 100% SoC but sometimes it is seemingly at random, without grid power loss.
Setting sleep timer to never does not resolve the problem. ECO mode is off. No alert/error messages are provided through the app.
AC180P2335000591915
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, @BLUETTI_CARE
Could you please push firmware update for my station AC180P? I have the same problem with turn off in UPS-mode.
SN: AC180P2332001051891
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Thank you.
Hello @BLUETTI_CARE
I’m going to use my two AC180P as a UPS. Could you please send me firmware with fix to my devices:
AC180P2335001752640
AC180P2335001049809
Thanks!
Hello @BLUETTI_CARE
I’m going to use my AC180P as a UPS. Could you please send me firmware with fix to my devices:
AC180P2349001883813
ARM: v2089,02
DSP: v2088,02
BMS: v1039,01
Thanks!
I’m going to use my AC180P as a UPS. Could you please send me firmware with fix to my device: ac180p2344000967724
Hello @BLUETTI_CARE
AC180P2341000546587
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Thanks!
Hey, could you also push new 04 firmware to me? Thanks!
AC180P2335001664744
ARM: 2089.02
DSP: 2088.03
BMS: 1039.01
Hey @BLUETTI_CARE, same issue as everyone above faces. Randomly turns off, doesn’t always turn on afterwards.
S/N: AC18OP2335000483326
ARM v2089,02
DSP v2088,02
BMS most likely also v1039.01; the device is at another place and I didn’t catch its BMS version in the screenshot of the bluetti app that I made.
Thank you!
Hello @BLUETTI_CARE
I’m going to use my AC180P as a UPS. Could you please send me firmware with fix to my devices: ac180p2341000784793
Thanks!
Can u sand update to my station, have same problem
AC180P2335001419700
Hello @BLUETTI_CARE , thank you for your work.
Could I please get this firmware too?
AC180P2335000607234
ARM v2089.02
DSP v2088.02
BMS  v1039.01
Привіт @BLUETTI_CARE
Я буду використовувати свій AC180P як ДБЖ. Не могли б ви надіслати мені прошивку з виправленням на мої пристрої:
AC180P2332001240258
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Дякую!
Hello! @BLUETTI_CARE
Update the firmware on my AC180P for stable operation.
AC180P2341000350659
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thank you
Hello. Same problem here. Can you please push new firmware version to me?
AC180P2342000262622
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi, same problem, AC180P turns off in UPS mode (ECO off).Can you please push update to my device?
SN - AC180P2332001245638
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Please provide me the new firmware for my station to work in UPS mode
SN - AC180P2332001358921
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Будь ласка, надайте мені нове програмне забезпечення для моєї станції для роботи в режимі ДБЖ
AC180P2344004367289
ARM: v2089.02
DSP: v2088.02
BMS v1039.01
I would also like to receive the update to fix same problem
AC180P2335001812882
ARM - 2089,02
DSP - 2088,02
BMS - 1039,01
