AC180P turns off randomly
With new firmware AC180P (2342000664076, DSP 2088,03) became slightly better — two days seemingly without interruptions of AC output, even EB3A (2244003022538, DSP 2052,51) turned off 4 times in one hour yesterday once but AC180P seemingly acted as UPS like it should.
But anyway today during short grid disconnection (global electricity turnoff) AC180P just turned off completely again — green button became gray, 0 AC output.
And another turning off in 3 hours while electricity didn’t even blink. Seriously, sometimes it’s just unuseable in UPS mode — turnings off are more frequent than without Bluetti devices. So what will you recommend to do next?
I have the same problem…
when at 100% battery and losing power from the grid the station shut downs by itself (sometimes). Please send or push this new firmware update to me.
ac180p2342000071792
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Hi, I have the same problem. Could you please send me an update?
AC180P2349000709407
ARM - 2089,02
DSP - 2088,02
BMS - 1039,01
Hello
I have same issue with shutdowns
Could you send firmware update to me?
S/N AC180P2349001406843
ARM v2089.02
The firmware will be pushed in 24 hours for the above request.
@Yaroslav Let me check with our technicians. If I get any update, I will let you know ASAP.
I have been testing the new firmware for a couple of days. And it seems I have found steps to reproduce another bug. Now, everything works correctly at 100% charge. But when the battery discharges to 99% with the device connected to the power grid during the switch to charging mode, the device shuts down.
Steps to reproduce:
  1. Charge to 100%.
  2. With the grid, wait until the battery discharges to 99% and the device tries to switch to charging mode. (At this moment, the device shuts down completely)
    AC180P2349001578074
    ARM v2089.02
    DSP v2088.03
@okyesanap There is another new firmware, please have a test. Looking forward to your update.
@BLUETTI_CARE Thank you! Received the update. Will write a report in a few days - on Friday-Saturday.
I have the same problem:
AC180P2348000993279
ARM v2089.02
I have the same problem on my device:
SN: AC180P2349002018775
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
my post with details
@Jinx1991 @Grigoriy The new firmware will be pushed to your AC180P.
@BLUETTI_CARE I have been testing for 2 days. My grid sometimes drops to values when the device stops charging. And even in this mode, there was not a single shut down. So I can say that the bug which was at 99%-100% charge was fixed. Well done!
@okyesanap Thank you so much for your update.
Hello, I have the same issue.
SN: AC180P2349000435621
ARM v2089.02
Could you please sent the new firmware to my device ?
Hello, I have the same problem as well. Device turns off randomly + doesn’t work as an UPS when electricity in the apartment shuts down, could you please send me a new firmware with the fix? Thank you
SN: AC180P2349001064502
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
After update to DSP v2088.04 problems gone and it is working fine, thanks!
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2348001002962
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
@mykolasus @retrogott @Vlad1 The firmware will be pushed in 24 hours.
