AC180P turns off randomly
I’m expecting new firmware too. Thx a lot.
AC180P2349000731658
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Another question - When all users will be able to get actual firmware?
Hey, I have the same problem- my Bluetti completely shuts down when electricity goes off. I have to turn it on manually and then all works fine. Pls push this new firmware for me too
AC180P2349001626912
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hey, could you also push new 04 firmware to me? Thanks!
AC180P2349000913774
ARM: 2089.02
DSP: 2088.02
BMS 1039.01
@moni @Sergeylitv The firmware has been pushed, please check.
When a firmware upgrade has a large number of resolved cases, the firmware will be pushed to all users.
Same symptoms here. No shutdown at 100%, but shuts down at 99% when connected to the grid with AC load. Both ECO off. Please push DSP 2088.04 to me as well.
AC180P2335001858093
ARM v2089.02
DSP v2088.03
BMS v1039.01
@BLUETTI_CARE hey, you’ve missed my message
AC180P2349001626912
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello
I have the same problem. Please, send me a new firmware to fix it.
:blush:Thanks
AC180P2349001523380
ARM 2089.02
DSP 2088.02
BMS 1039.01
Thanks a lot for pushing the update. Today I tried to see if it helped me or not, and it helped.
I received the new firmware this morning, and it looks like it fixed the random shutdowns and now works as a UPS. I will be monitoring the situation over the next few days, but I hope the issue won’t come back.
Thank you @BLUETTI_CARE
Hi! @BLUETTI_CARE
AC180P2344000964876
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please, help me to fix this issue.
Thanks!
Hi! @BLUETTI_CARE
I have the same problem with my bluetti ac180p, it just randomly turns off.
AC180P2349001114818
ARM v2089.02
DSP v2088.02
BMS v1039.01
Здравствуйте, у меня такая же проблема. Не могли бы вы выслать мне новую прошивку с исправлениями? Спасибо
Серийный номер: AC180P2341000439027
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Hello @BLUETTI_CARE
AC180P2344003062857
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P turns off voluntarily when working as UPS for the fridge with electricity in the grid, and thus also turns off the fridge
Can you send me DSP 2088.04, maybe it can help
The request above will be processed in 24 hours.
Hello @BLUETTI_CARE
I have faced with the same problem
AC180P2344004182896
ARM v2089.02
DSP v2088.02
BMS v1039.01
Please push new firmware for my device as well, thank you!
Hi @BLUETTI_CARE,
Same issue here. Could you please push this fw to my device as well?
AC180P2349000774724
ARM 2089.02
DSP 2088.02
BMS 1039.01
I would also like to receive the update
AC180P2335001966287
ARM v2089.02
DSP v2088.02
BMS v1039.01
Привіт,у мене проблема з відключенням.Не могли б ви надіслати мені оновлення мікропрограми?
AC180P2344003113958
ARM v2089.02
DSP v2088.02.
BMS v1039.01
Request above will be processed in 24 hours.
AC180P2349001072782
ARM: 2089.02
DSP: 2088.02
BMS 1039.01
And
AC180P2349001669099
ARM: 2089.02
DSP: 2088.02
BMS 1039.01
