AC180P turns off randomly
Пришлите новую прошивку, пожалуйста
АС180Р2344002046903
ARM 2089.02
DSP 2088.02
Please send the update of firmware
AC180P2344000475786
hi @BLUETTI_CARE ! Same issue for me, please provide with the updated firmware:
AC180P2344000860966
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Thank you!
Kind regards,
Inna
@BLUETTI_CARE , why don’t you push new update for everyone, lots of people having same issue… I have it too - new AC180P is working in UPS mode, when the grid turns off it randomly can immediately turn off , you can’t turn it on it for few seconds, then after turning it on it shows incorrect w load (more than 1000, when in fact its just a fridge and other devices connected that can theoretically consume less than 300 w in total only in my case)
Eco mode = off, autosleep = never, power lifting = on, charging = standard, AC and DC on with some constant load
So please can you send me a new update
AC180P2335001370612
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Hello @BLUETTICARE! Please send me new firmware update for my AC180P for better UPS mode experience :)
Model: AC180P
SN: 2332001198585
ARM v2089.02
Wrong, the fans keep spinning forever like it’s over 1000 watts of the constant load until I increase the wattage to get over 15 watts, and after that the fans slow down. That is anything but optimal behavior. I keep my PC on all night to not get woken up by the fans.
Also, why the station doesn’t show the wattage under 15 watts in the first place?
If the fan problem has been optimized in the past, there’s still room for improvement because it’s really annoying. I have 2 much cheaper Chinese 600wh power stations that stay dead silent on sub 15 watts.
AC180P2335000461932
I bought a Bluetti AC180p charger. I use it as ups for my PC. For some reason, if my power goes out, the device also turns off and I have to turn it back on. What could be the problem. Thank you.
When at 100% battery the station shut downs by itself after some time.
@BLUETTI_CARE Could you please also push this firmware to me?
AC180P2335001106275
ARM 2089.02
DSP 2088.02
I want to receive updates for stable operation of the station in UPS mode.
Model: AC180P
Serial number: 2335000491972
ARM: v2089.02
DSP: v2088.02
Can you help me?
Hello @BLUETTICARE!Please send a firmware update to my device. the same problem. random shutdown in UPS mode.
Model: AC180P
AC180P2344004035009
ARM v2089.02
Good afternoon. I have the same problem, after charging to 100 percent it turns off even with a consumption of 220. The ups mode does not work correctly, I need help. The DSP firmware version costs 2126.02. ARM 2125.01
Thank you
AC180P2344000390880
Model: AC180P
AC180P2335001232835
ARM v2089.02
Model: AC180P
AC180P2332001262405
ARM v2089.02
@BLUETTI_CARE Hi. After updating firmware everything works as expected, thanks!
Hello @BLUETTICARE! Please send a firmware update to my device. the same problem. random shutdown in UPS mode.
Model: AC180P
AC180P2332001262405
ARM v2089.02
Hello @BLUETTI_CARE Please send a firmware update to my device. the same problem. random shutdown in UPS mode.
Model: AC180P
AC180P2332001262405
ARM v2089.02
Model: AC180P
AC180P2342000156537
ARM v2089.02
Model: AC180P
Serial number: 2344000685706
ARM: v2089.02
DSP: v2088.02
Can you help me?
The above serial number has been recorded, and the firmware will be pushed within 24 hours.
I will report this to R&D and let you know if there is an update.
