Please send a firmware update to my device. I have the same problem (AC turns off randomly). Thank you!
AC180P2438000848002
ARM 2125.03
DSP 2126.03
BMS 1048.05
AC180P2438000848002
ARM 2125.03
DSP 2126.03
BMS 1048.05
@BLUETTI_CARE Please send a firmware update to my device.
Model: AC180P
AC180P2335001585481
ARM v2089.03
DSP v2088.03
Thanks.
Hi, Care Team,
Kindly upgrade firmware for my Bluetti AC180P power station.
AC180P2434000679068
IoT v9046.01
ARM v2125.03
DSP v2126.03
BMS v1048.05
Hi! I have the same problem.
Could you please push this new firmware to me?
AC180P2352001232482
ARM 2089.03
DSP 2088.03
Спасибо! Все получилось.
Hi @barheta and @tlavrina, Now I have applied to upgrade your firmware.
Hi @caymanxt and @kovtyn2, Now I have applied to upgrade your firmware.
Prease update my power station to be able using UPS
AC180P2352000849290
ARM v2089.03
DSP v2088.02 → v2088.03
Hi @Sergei, Thank you for your feedback. I have forwarded your request to the R&D department.
However, due to a shortage of language professional staff, we currently lack the capacity to provide translations in Russian. This may be difficult to implement in the near future.
Hi @vynnykv, We have released a new DSP v2088.03 for the European version of the AC180P to address this issue. Please upgrade directly to resolve the problem.
If you can’t upgrade it directly. I’m afraid that you might be directly connecting to the AC180P via Bluetooth without logging into your Bluetti account and binding this AC180P to it. If this is the case, you won’t be able to complete the firmware upgrade. A direct Bluetooth connection only allows limited operational access and does not include firmware upgrades.
Please register and log in to your Bluetti account, then bind your AC180P. Next, click on ‘Settings,’ then ‘Firmware Upgrade,’ and click on the blue DSP icon to obtain the latest firmware. Proceed with the upgrade afterward.
Я мог бы помочь с переводом приложения на русский язык. У меня есть опыт языкового перевода игр с английского на русский язык.
Hi!
Please send a firmware update to my Bluetti AC180P power station.
AC180P2434003165901
IoT v9046.01
ARM v2125.03
DSP v2126.03
BMS v1048.05
Hi @Sergei, Thank you for getting back to us so quickly.
I have passed your feedback on to the R&D department and asked them to look into this matter. If necessary, we will reach out to you.
We appreciate your kind intentions and your help.
Hi @kostya1, I have submitted a request to push the new DSP firmware to your AC180P as per your request. It will be pushed on next Monday. Hopefully, this will help.
I have AC180P and there is a turbo charging mode problem. It`s not working.
AC180P2434000667634
IOT v9046,01
ARM v2125,03
DSP v2126,03
Hi, @BLUETTI_CARE
Have the same issue on the latest firmware: when no load in UPS mode station turns off in case of external grid outage.
SN: 2438000816752
IoT: v9046.01
ARM: v2125.03
DSP: v2126.03
BMS: v1048.05
Please send me the new firmware update
Also, does anyone know, why such updates are sent in manual mode by IT department?
Thank you in advance!
AC180P2440001956039
ARM v2125.03
DSP v2126.03
BMS v1048.05
AC180P turns off voluntarily when working as UPS for the fridge with electricity in the grid, and thus also turns off the fridge
Can you send me DSP 2088.04, maybe it can help
AC180P2440001956039
ARM v2125.03
DSP v2126.03
BMS v1048.05
Hi, I have the same problem. Could you please send me an update?
AC180P2438001639172
ARM - v2125.03
DSP - v2126.03
BMS - 1048.05
Добрый день!
Подскажите, почему блюетти отключается сам через 4 часа в режиме ожидания. ( режим АС сам выключается)
Серийный номер АС180Р2440001820741
ARM v2125.03
DSP v2126.03
BMS v1048.06
Спасибо!
Please send updates Thank you
