Hi ErlinUA, Now I have applied to upgrade your firmware.
Our IT department will push the latest version of firmware to your unit in 12 hours.
Hi @BLUETTI_CARE !
I have the same problem (AC180P turns off randomly)
Please give me a software update to:
AC180P2428000715202
lOT v9046.01
ARM v2125.02
DSP v2126.02
BMS V1048.03
Thank you!
Hi @OlexiiSh, Now I have applied to upgrade your firmware.
Our IT department will push the latest version of firmware to your unit next Monday.
Please upgrade the firmware at that time. Please do not load any device when upgrading it.
Hello! @BLUETTI_CARE I’m experiencing a similar issue with my AC180. It randomly shuts off even when it’s fully charged and plugged into the AC outlet. I originally intended to use it as an uninterruptible power supply (UPS), so I’m feeling quite disappointed with its performance. Any insights or solutions would be greatly appreciated!
AC1802403000032348
BMS V1033.12
ARM V2074.07
DSP V2078.06
Hello!
I have a problem with the UPS mode! The device is turned off when grid is down. This happens when the device is fully charged to 100% and running in pass-through mode.
Please, can you send me the new firmware for the device.
S/N AC180P2433000441768
IOT v9046,01
ARM v2125,03
DSP v2126,03
BMS v1048,05
Добрий день. Проблема використання станції в режимі ДБЖ. Періодично вимикається. Надішліть оновлення AC180P2352000872189
ARM v2089.03
DSP v2088.02
AC180P2352000872189
ARM V2089.03
DSP V2089.03
BMS V1039.01
Добрый день. Можно получить новую прошивку DSP V2088.04?
Спасибо!
Hi @Mithiin & @bluetti1717 & @Sergei, Now I have applied to upgrade your firmware.
Our IT department will push the latest version of firmware to your unit in 24 hours.
Hi @Ukraine, We have pushed the new DSP in batch.
I’m afraid that you might be directly connecting to the AC180P via Bluetooth without logging into your Bluetti account and binding this AC180P to it. If this is the case, you won’t be able to complete the firmware upgrade. A direct Bluetooth connection only allows limited operational access and does not include firmware upgrades.
Please register and log in to your Bluetti account, then bind your AC180P. Next, click on ‘Settings,’ then ‘Firmware Upgrade,’ and click on the blue DSP icon to obtain the latest firmware. Proceed with the upgrade afterward.
I hope it does help.
А можно сюда ссылку, где пройти регистрацию и привязать свой АС180Р?
Спасибо, обновил. Но прошивка не изменилась. Все числа остались прежними в прошивке! Так и должно быть?
Здравствуйте.
Получил в приложении уведомление о новой версии прошивки 2126.04.
Я на данный момент не обновлял DSP, так как после испытаний станции в режиме бесперебойного питания , в условиях отключения электричества, при заряде аккумулятора на 100%, было выявлено отсутствие проблемы отключения станции. Станция работает штатно. Поэтому, обновление на данный момент не совершаю.
Запрос на обновление сделал после того, как узнал в видеообзорах о проблеме отключения зарядной станции и решении этой проблемы с помощью обновления DSP. Но, как показал опыт эксплуатации, у меня эта проблема отсутствует на данный момент. Но, это результаты использования станции одного дня.
Буду наблюдать дальше. Возможно всё будет в порядке. А в случае возникновения проблемы, сделаю обновление.
Команду BLUETTI хочу поблагодарить за работу, и за заботу о пользователях зарядных станций. Приятно видеть профессиональную работу специалистов.
Hi @Ukraine, Have you successfully upgraded to DSP v2088.03 and are now looking to upgrade to DSP v2088.04?
Why hasn’t the function of restoring the previous state on power been added to the AC180p yet? I see that even AC70p already has it, although it is lower in the bluetti lineup???
Здравствуйте.
Скажите, есть ли возможность добавить в приложение для андроид русский язык?
Please send a firmware update to my device. I have the same problem (AC turns off randomly). Thank you!
AC180P2438000848002
ARM 2125.03
DSP 2126.03
BMS 1048.05
@BLUETTI_CARE Please send a firmware update to my device.
Model: AC180P
AC180P2335001585481
ARM v2089.03
DSP v2088.03
BMS v1039.01
Thanks.
Hi, Care Team,
Kindly upgrade firmware for my Bluetti AC180P power station.
AC180P2434000679068
IoT v9046.01
ARM v2125.03
DSP v2126.03
BMS v1048.05
Hi! I have the same problem.
Could you please push this new firmware to me?
AC180P2352001232482
ARM 2089.03
DSP 2088.03
BMS 1039.01
Спасибо! Все получилось.
