@bds3 Please log in with your account and connect with Bluetooth, you will see the BMS update of 1017.03. If you have further question, feel free to ask me.
Please push update to 2214000021643
thank you so much!
@Jack00 Do you mean BMS version 1017.03? This version has been pushed to all AC200MAXs. Please connect with Bluetooth to check. After updating, please do a full cycle of charge and dis charge (When you do the full cycle of charge and discharge, please ignore the SOC. Please completely drain the battery until it automatically shuts down, and then charge it with AC until it is fully charged and automatically shuts down.).
I have two AC 200 max one with two 230 connected and one with one 230 connected.
Could I experience the same problem?
The serial numbers are :
1: 2226000077441 with 2 B230
2: 2215000344647 with 1 B230
Good evening,
my AC200 suddenly has the same issue the people reporting Here. Please Help.
SNo: 2217000471124
Same situation here. I charged the machine to 100% by AC last week. I have not put any load to it and it’s been off since then. I turned it on this morning and the reading is 55%. SN-2337001704508 Discharging the machine now and will recharge to 100% by AC to see if that helps at all. Please send any firmware updates needed.
Thanks.
