Solar X 4K needs to be unplugged every morning and re plugged in order to work
@BLUETTI_CARE are you able to assist ?
"Hi I have same problem, can I have new firmware pushed in to my Solar X 4K as well
SN 2528000808000
Thank you"
Hi @hnymann, thank you for your update.
We hope everything goes smoothly from here!
Hi @Fibak, thank you for contacting us.
May I have the current firmware version of your SolarX 4K?
Then we will push the new firmware soon.
Looks like new firmware update is now available, Thank you
I will let you know how it went
I have installed the firmware that was pushed to my Solar X 4K and it seems to be working fine.
IOT v8029.10
DSP v9092.12
What I have noticed is that the Fans on Solar X 4K are way quieter. They are still audible but it sounds like before it was running 100% all the time and now its about 30%. Was this part of the update ?
Less noise is welcomed, but I want to be sure its not affecting cooling.
I have noticed one more thing which I have not seen before. After batteries are charged to 100%. Solar X 4K stops charging and is flashing red led with error in the app E010 Battery Voltage High / Hardware Battery Over Voltage. This is not recovering when charge % on batteries drop below 100%, but 2 x XT60 ports still continue to charge Apex 300. Only way to make it work is to disconnect solar input from Solar X 4K and reconnect cable between Solar X 4K and Apex 300.
This has happened now two days in a row and I have not seen that before firmware upgrade.
Can you please assist with this problem ?
Kind Regards
Hello @BLUETTI_CARE,
I just wanted to follow up, as I think it has been long enough now to be certain. My SolarX 4K has been completely reliable since those last updates. Thank you very much for continuing to work with us for this resolution.
Also, as @Fibak mentioned, the cooling fans in the SolarX are running at lower speeds and are much quieter. I can tell they are running still, and that they sound like they are varying in speed, so I am assuming their speed will be related to the internal temperature. My equipment is in a basement area that usually is around 65 Fahrenheit (18 Celcius), so the fans won’t have to run much, and the quiet in that room is appreciated!
Glad to hear you got it fixed hnymann. I would also like to get mine working properly, so I can hook up my other Apex 300 and the Hub A1, which has been gathering dust since last Fall. So, is there now an actual firmware update, or are we still doing the pushing of updates, whatever that means?
Hi @Fibak, thank you for the update.
To push the new firmware to all your devices, we still need the SN codes and current firmware versions of both your Apex 300 and battery pack. Could you please provide them?
We look forward to your reply.
Hello @Clay1,
The updates being pushed are firmware updates, so that is the same. Bluetti, from what I notice, sometimes puts out generally available updates, and I assume that these are known stable updates. However, for the types of situations that we are finding ourselves in where a fix is needed, they seem to use a directed update method. I believe this is to limit potentially unstable fixes from going “wild”, so to speak, before determining if they are stable enough for general release. To me this is a good methodology, and I have become quite comfortable with working with Bluetti’s support people to resolve issues this way, effectively working together to make these systems better for everyone.
I have noticed that my SolarX 4K has become more efficient in using my solar panels with these updates, now getting around 200 to 300 watts more than what my AC300 was able to extract with the same panels.
Hi Hnymann and thanks for the response. I hope this does increase my wattage, as it seems to not want to go above 1500 watts, which is less that half of their rating and they are only about six months old. I’ll do the update soon. Thanks again to you and Bluetti Care.
Hi @BLUETTI_CARE I have applied new firmware yesterday and today battery was charged to 100% and no errors thus far. Seems to be working ok. Thank you.
Can i have it pushed to my other 2x Apex 300 please.
SN: AP3002519000157745
SN: AP3002519000164352
Thank you for your support
Fibak
Hi @Fibak, thank you for letting us know.
I am glad to hear that the new firmware works well.
We need the current firmware version of your 2 Apex 300 units. Could you please provide screenshots of the firmware for both units? This will allow us to push the corresponding new firmware to you.
HI @BLUETTI_CARE After testing my Apex300 and installing pushed ARM firmware, the problem is still not resolved
Device is working fine up until charge reaches 100%. Once its there Apex 300 error icon is flashing and App showing 2 errors
E074 BMS System Fault
after that “Solar X 4K” stops charging “Apex 300” and will not resume charging until cable in-between them is disconnected and reconnected back again.
Apex 300 still continues to charge via XT60 ports once charge drops below 100%
My Main APEX 300
SN- AP3002519000329209
IOT - 8026.13
ARM - v2204.81
DSP - v2174.16
BMS - v1073.07
My Solar X 4K
SN - 2528000808000
IOT - v8023.10
DSP - v9092.12
My 2 remaining backup APEX 300 ( its not main priority, I would like 1st one to work correctly first )
IOT - 8026.13
ARM - v2204.13
DSP - v2174.16
BMS - 1073.07
Can you please help me with this problem
Thank you
Fibak
@BLUETTI_CARE, any chance I can get a response to the problem above ?
Thank you
@BLUETTI_CARE hello ?
Hi @Fibak ,
Hope you are having a wonderful day.
Regarding the E010 and E074 error codes you encountered, our team has pushed a new firmware version DSP v2174.17 to your device .
Please complete the update and let us know if the issue persists once the charge reaches 100%.
@BLUETTI_CARE Thank you
I will install it this evening and test it tomorrow
Thank you for your help. If this will resolve my problem, Can i have it pushed as well to my two other APEX 300 ( details above )
Kind Regards
Fibak
Hi @BLUETTI_CARE Thank you for the update. Errors are not popping up now
However problem remains.
All is working good until Apex 300 reaches 100% state of charge.
Solar X 4K then stops charging and red dot on it is flashing
2 x XT 60 ports continue to charge Apex 300, but Solar X 4K never starts charging again even if state of charge drops below 100% on APEX 300.
Only way to make it charge again is to disable PV input on Solar X 4K and disconnect cable between it and Apex 300.
Reconnect after few seconds and enable PV input and it will start charging again as long as state of charge is below 100%
Not sure if this can be addressed somehow.
As the workaround that I have found requires physical presence, means system cannot be left unsupervised for even a day or Solar X 4K will never start charging the next day.
Is this a problem with other user or perhaps one of my units is faulty ?
Looking forward to hear from you. Thank you for your support
Kind Regards
Fibak
Normally, updating the firmware can resolve this issue.
We consider your firmware upgrade may not have been completed successfully. Could you please provide screenshots of the App firmware version page for both Apex 300 units for our verification?
Please note: connect via Bluetooth first, then tap the upgrade option to proceed with the update.
Hi @BLUETTI_CARE
Here is a screenshot of the firmware versions currently installed.
Please let me know if you need any additional information.
