Same issue on my ac180p. Please include me
Sn: 2332001611209
Arm: v2089.02
Dsp: v2088.02
Bms: v1039.01
Sn: 2332001611209
Arm: v2089.02
Dsp: v2088.02
Bms: v1039.01
Mine also makes this noise, could I get the update too?
This is my second replacement… I have had to request this fix on all the supplied units!~
SN
2418000168443
BMS
B1033.12
ARM
V2074.07
DSP
V2078.06
AC1802418000168443 via app
or could be 1040353L50 8241700185 ( as per sticker on box
Ta
Firmware is expected to be pushed out within 24 hours, so please update then. :)
Thank you… I will keep an eye out for it
@TRex888 A firmware is available to address this issue. May I ask which country you are in? I need to confirm the location version of the machine.
I am based in Australia ![]()
Received, firmware will be pushed within 12 hours.
Hi. I have the same problem. Please send firmware udate. SN: AC200PL2426003401210
Hi. I have the same problem. Serial Number: AC200PL2431004623797
Hi @BLUETTI_CARE,
I have an AC180 and recently connected a solar panel to find the same clicking issue when the light is dim but not generating any power.
S/N: AC1802446002841069
ARM: v2074.08
DSP: v2078.06
BMS: v1033.12
Is there a relevant update for this?
Thanks!
Dale.
Hi @Daleyb93, regarding this matter, I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 24 hours.
Thanks, I’ve updated the firmware and it seems to have resolved the issue!
Is there any reason why this firmware isn’t pushed to devices as standard? Any potential downsides of it?
I hope that future updates don’t revert it to the clicking version.
Thanks again,
Dale.
Hi @Daleyb93, thank you for your feedback. We are glad to hear that the new firmware works well.
There are no potential downsides to this firmware. The reason we haven’t pushed it out in batches is that the clicking noise issue occurs relatively infrequently. Most users do not need this upgrade.
