@scoop98 @Wei Sorry that I have seen your request till now. The firmware has been pushed. Please update the DSP firmware to tets. Looking forward to your update.
Same here can I get the firmware update:
1802316001125271
ARM: v2073.04
DSP: v2077.06
BMS: v1033.08
Thanks, I have installed .07!
Im having the same issues. May I have the firmware update that corrects this?
SN 2316000915938
BMS: v1033.08
ARM: v2073.04
DSP: v2077.06
Thanks!
Thanks for the information. I will push the firmware for you in 24 hours.
SN 2315000676944
BMS: v1033.08
ARM: v2074.07
DSP: v2078.06
Note this is a replacement model, I had to ask for the same fix on the original AC180 that had a Dc Converter Fail
Thanks!
Hi, I have the same issue but with an AC70, is there a similar firmware upgrade for it?
SN: AC702346003113838
ARM Current Vesion: v2082.05
DSP Current Version: V2106.04
Mine also makes this noise, could I get the update too?
SN
2336000174633
BMS
B1033.08
ARM
V2073.04
DSP
V2077.06
@BLUETTI_CARE @BLUETTI
SN
2336000174633
BMS
B1033.08
ARM
V2073.04
DSP
V2077.06
@BLUETTI_CARE
Mine still clicks about 10-15 times in the morning and evening. Anything else you can do?
@Paoferr I’m sorry that DSP2077.07 is the latest firmware for this problem. I have nothing to do at this time.
My Bluetti AC200L has the sam problem. Where do I find the information you need to push the update?
My Bluetti AC170 also clicks on low solar input. Current firmware:
ARM: v2082.10
DSP: v2085.05
Is there a fix for this?
Thank you!
I’m having the same issues with my AC200L. May I have the firmware update that corrects this?
SN 2344001076179
BMS: (Application says “Version”)
ARM: v2134.04
DSP: v2098.10
Let me know if you need anything else.
Thanks!
I have the same issue with my AC180P. please help
Sn: ac180p2332001611209
Arm: v2089.02
Dsp: v2088.02
Bms: v1039.01
It’s been 2 months since I have posted about this topic asking for help and I have received no reply.
This issue is an absolute deal breaker when concidering solar power banks.
I have to unplug my power bank every night and replug it in every morning. Otherwise it wakes me up at sunrise with a very annoying clicking sound that lasts almost 30 mins.
If I knew this was an issue with the Bluetti power banks, I never would have purchased one.
I am very disappointed that Bluetti has not replied to either of my requests to help remedy this issue.
I can’t in good conscience recommend Bluetti products to anyone.
