Low voltage warning with solar panel not charging. EB3A
Sure I am…You can’t measure current unless there is current flowing. For your multimeter you have to separate the positive feed wire and bypass it by running it through the multimeter while under load. You are not producing current with no load attached and therefore cannot measure amperage.
EDIT: Never mind, I managed to get it charging
Please push firmware update for mine too.
EU Version
Current FW:
ARM v2063.03
DSP v2052.11
Same problem, INPUT flashes and no charging even while panels are in full sunlight.
Error A008
Thanks!
I have the same issue
SN: EB3A2544110840296
Hi @abdmission , please tell us the current firmware version of your EB3A.
Then we will check if there is any new firmware for you.
