Low grid voltage error on AC180P
@BLUETTI_CARE
I have the same issue. Please assist.
in the App I see alarm “Grid Voltage Low - E114”
Bluetti AC60P
S/N: AC60P2352000274990
BMS: v1042.03
ARM: v2090.04
DSP: v2075.04
Hi @deadline, We strongly discourage reverting to the original firmware, as the new firmware effectively improves AC180P’s charging performance under unstable grid conditions.
If you’re concerned about the UPS switching issue, please disable Grid Self-adaption mode. This will help reduce the UPS switching time significantly.
Hi @oOiam4everOo, we have applied to upgrade your DSP to our IT department.
They will push the latest version of firmware to your AC60P in 24 hours. Please upgrade it tomorrow.
Hi, having similar issue on my AC200PL2433000041667 , any chance to get it working?
Thanks for the quick response. DSP was upgraded. Currently, the grid voltage is 212V, but I’ll check during the whole day if voltage goes down and how it will work with 190V and less.
it did not want to upgrade, but later on it did DSP upgrade auto git adjustment option started working fine, issue’s self resolved :)
@Bluetti team - pls upgrade the app so people can push force update buttons (from time to time it is unavalilable)
Hi @oOiam4everOo, Thank you for letting us know.
We are expecting your feedback.
I hope it does help.
Hi @viktar, It seems the issue has been resolved, correct? We’re glad to hear that.
Generally, as long as customers have properly registered and linked their devices, they will receive an upgrade notification. Customers can then decide whether to upgrade or not. If they wish to upgrade, they simply need to click the Upgrade button.
We respect our customers’ right to choose whether to upgrade, as forcing updates might infringe on the preferences of those who do not wish to upgrade.
If you encounter any issues during the upgrade process, please contact customer service for assistance.
Hi ,
You can consider me as another AC70P customer experiencing the same E114 errors when the voltage drops. What are the chances of getting custom firmware with slightly adjusted thresholds to support such circumstances?
S/N: AC70P2441000237325
IOT: v9046.01
ARM: v2152.04
DSP: v2112.06
Thanks in advance.
Hi @Denlapshyn, Regarding this issue, please first upgrade the Bluetti app to the latest version, then enable Grid Self-adaption and change the charging mode to silent mode. Does this help?
If it is confirmed to be ineffective, we will then push the new firmware to you.
Hi ,
I looked at the forum before writing and immediately made all the recommendations. The Bluetti program is updated to the latest version, network self-adaptation is enabled. Charging mode is silent mode. This does not help
Thanks in advance.
Hi @Denlapshyn, Thank you for getting back to us so quickly.
Now I have applied to upgrade your firmware. Our IT department will push the latest version of firmware to your unit in 12 hours.
I updated my AC70P to the new firmware, (v2112.71), and can confirm that it charges properly at the current voltage of 183V. Thank you very much.
Hi @Denlapshyn, Thank you for letting us know.
We are glad to hear that!
We hope everything goes smoothly from here!
Hi ,
S/N: AC70P2441002722490
IOT: v9046.04
ARM: v2152.05
DSP: v2112.06
Thanks in advance.
@BLUETTI_CARE, please take a look
Hi @phobbii, yes, we would like to help you.
Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
Hi ,
You can consider me as another AC180 customer experiencing the same E114 errors when the voltage drops. What are the chances of getting custom firmware with slightly adjusted thresholds to support such circumstances?
S/N: AC1802422001947098
IOT: v9046.01
ARM: v2074.07
DSP: v2126.02
Thanks in advance.
@BLUETTI_CARE, please help me with those errors.
Hi @Prophecylife, can you confirm you have turn on the Grid Self-adaption?
