Low grid voltage error on AC180P
Hello @BLUETTI and @BLUETTI_CARE , I followed the instructions provided in the app: installed the latest firmware version, turned on grid self adaption and set the charging mode to silent. The voltage is around 180V, but unfortunately the charging doesn’t work :(
Do you have any suggestions?
Hey, i live in Ukraine and there is always low voltage (170-190) from a socket after a power shutdown, and i’m getting error E114 so could you please push me a modified firmware so i can charge my power station.
SN: AC180P2438000551133
BMS v1048.05
IoT v9046.04
ARM v2125.04
DSP v2126.03
Hi
I have two AC180p stations. Currently, there are problems with electricity in Ukraine, and the voltage is around 180 V. Both stations are not charging even though the firmware has been updated and grid self-adaptation mode and silent mode are enabled. Please update the firmware on both stations for me.
AC180P2349002264629
ARM v2089.04
DCP V2088.03
AC180P2445000332065
ARM V2125.04
DCP V2126.03
BMS 1048.05
hi there.
had the same issue with AC180P not charging at low voltage throwing E177 despite voltage is something of 90% of 230V
please send me an update if possible
AC180P2433001710648
IOT
v9046.04
ARM
v2125.04
DSP
v2126.03
Hello @BLUETTI and @BLUETTI_CARE, I have the same issue with low grid voltage. Is it possible to push an update for my AC180P?
Serial: AC180P2335001012430
ARM v2089.04
DSP v2088.03
Cheers
I’m living in Ukraine and there always low voltage (180-190v) from a socket after a power outage/blackout. When attempting to charge the device, error E114 appears. Grid Self-adaptation mode and Silent (Eco) mode did not solve the problem.
Could you please push me a modified firmware if possible, so I can charge my power station safety? Thank you in advance.
I cannot imagine how I could work remotely without your product.
Device s/n: АС180Р2428000423367
IOT: v9046.04
ARM: v2125.04
DSP: v2126.03
BMS: v1048.05
Hello @BLUETTI_CARE,
I have the same issue with low grid voltage. Silent charging mode and grid self-adaptation are enabled. Could you please send a firmware update.
Device info:
Model: AC180P
S/N: AC180P2428001680150
IOT: v9046.04
ARM: v2125.04
DSP: v2126.03
BMS: v1048.05
Hello @BLUETTI_CARE ! I have an AC180P in use. I also live in Ukraine and unfortunately I have the same problem - the voltage in the network now often drops below 190 V and is in the range of 180-190 V. During charging, it gives an error E114. Is it possible for me to also update the firmware so that the AC180P can charge?
AC180P2432000024708
IoT v9046.04
ARM v2125.04
DSP v2126.03
BMS v1048.05
Hello, I have registered your firmware upgrade. Please wait patiently.
Hi @Dmytro000, we would like to know if your app has displayed any error messages, and if so, what the error code is.
Please provide us with your device’s SN number so that we can push the firmware update to you.
Hi @Foldren, thank you for contacting us.
Hi @Alexart, thank you for getting in touch with us.
Hi @dmytro.postman, thank you for letting us know.
Hi @kso, thank you for getting in touch with us.
The error code is E114 - Grid Voltage Low.
AC70P2402000952276
Thank you for your response!
Hi all, for Ukrainian users who are unable to perform AC charging under low grid voltage conditions, please click the link below to fill in your SN, DSP version and other relevant information.
https://feedback.bluettipower.com/questionnaire/69707f00fbdb8877850611a2
We will push the new firmware to resolve this issue. Thank you for your cooperation.
How long do I have to wait after filling out the form? I have a similar problem. Sorry to bother you, but I need it for work and need to know how long this problem will be shared?
Thank you
AC180P2341000235939
Hello, @BLUETTI_CARE! I use the Bluetti AC180P power station (bought November, 19, 2024) Till today the the grid voltage was upper 190 V and the station charged correctly. Today in Kyiv voltage dropped and was in range 169…188 V, so the station have displayed me an error E114. I have chosen the “Self-adaptation” mode and the “Silent” mode of charging in Bluetti app, but an error didn’t disappeared.
So, is it possible to upgrade the firmware to prevent this error?
S/N: AC180P2438000774602
IOT: v9046.04
ARM: v2125.04
DSP: v2126.03
BMS: v1048.05
Many thanks.
