EB3A Shuts off at 75% and wont turn back on
@BLUETTI_CARE
Hello… I have the same issue @75%
sn: EB3A2229002072660
current arm: v2057.11
DSP: v2056.10
How do I fix this, pls?..
Hi @Phoenixwa, I have submitted a request to push the new firmware to your EB3A as per your request. It will be pushed on Monday next week.
Hi @bluetti_sdedg1gmailcom, Can you tell us the current firmware version of your EB3A? When you mentioned that the app is not letting you upgrade, can you take a screenshot for us?
I’m afraid that you might be directly connecting to the EB3A via Bluetooth without logging into your Bluetti account and binding this EB3A to it. If this is the case, you won’t be able to complete the firmware upgrade. A direct Bluetooth connection only allows limited operational access and does not include firmware upgrades.
Please register and log in to your Bluetti account, then bind your EB3A. Next, click on ‘Settings,’ then ‘Firmware Upgrade,’ and click on the blue icon to obtain the latest firmware. Proceed with the upgrade afterward.
I hope it does help.
Hi @BLUETTI_CARE , same issue here
Screenshot_20241108_192407_BLUETTI
Can you provide firmware update
I am having the same issue. What is the latest ARM and DSP I have ARM v2057.11 and DSP v2056.10.
Hi @dmerinoh, Thank you for your attention to Bluetti.
Without it, we don’t know which version should be pushed to your device.
Hi @skcahill, Thank you for your attention to Bluetti.
Can you tell us the SN number of your EB3A?
Without it, we can’t push the new firmware to your device.
The latest version of firmware for your EB3A is DSP v2056.15 and ARM v2057.12.
I believe it is
EB3A2235000390655 or 80367QC22340684
Regards, Scott
If the plan does not work, change the plan, but never the goal.
Hi @skcahill, Thank you for getting back to us so quickly.
Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Got it and did the update. Prior was showing 100% charged after upgrade went down to 35% immediatly. Hopefully it is fixed. Thanks, Scott
Hi @skcahill, It’s possible that the upgrade process used a significant amount of power.
Could you try recalibrating? This should help resolve the issue.
  1. Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
  2. Please charge it again, please do not load any device when charging it, and do not interrupt it while in charge.
If not, please contact us for further service.
Hello, I have the same issue on about 50% SOC. Could you please also push me a fix?
EB3A2247003099853
ARM v2063.03
DSP v2052.11
Hi @S.Savchenko, Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Help. I have the same issue, shutdown at 44%
EB3A2442000104485
IOT:V9046.01
ARM:V2118.09
DSP:V2117.08
Hi @unexisted09, your firmware is already up to date, and we don’t have any new updates to push at this moment.
Please follow the steps below to recalibrate it and resolve this problem:
If not, please contact our customer service team for further service.
Cant reach the soc to 0% it shutdown on 46 - 44 then i need to connect the charger
Hi again, unfortunately, I haven’t received the firmware update yet. Could you please let me know if it has been pushed?
Hi @S.Savchenko, We really want to help you, but I am sorry our engineer told us that your firmware is already up to date.
At this point, we can only recommend contacting customer service to arrange for a repair. If you’re unsure how to contact customer service, please send us your order number and the platform you ordered from, and I’ll help you find the corresponding customer service email.
@BLUETTI_CARE I had a similar issue last night during a power outage. It’s been in UPS mode for a month or two and was fully charged, then ran my wireless router for a few hours during the outage.
I unplugged it showing 41% to run my cpap, but it died immediately after moving it to another room: none of the front buttons worked, and it didn’t show up as a Bluetooth device in the app.
Weirdly, the next morning after power was back it showed 75% battery when I plugged it in and it immediately started working again.
EB3A2317000778377
ARM V2062.03
DSP V2056.12
Hi @Gthiem, Now I have applied to upgrade your firmware.
Our IT department will push the latest version of firmware to your unit in 12 hours.
