EB3A shows overload when not overloaded
Yes, please, rollback my Bluetti EB3A to the original firmware.
@BLUETTI_CARE Mine also has the Inverter overload/A001 Error issue and once in that state, will turn off AC and continue to drain the battery.
Can I please get the upgrade?
Thanks for your reply. Below are the requested details:
EB3A 2227 0010 41132
ARM v2053,08
DSP v2052,11
Hi @ICbook, I have applied for the service, and we will fulfill it in 24 hours, please upgrade the firmware tomorrow.
I hope it does help.
Hi @rgb, Yes, we have a new firmware that could resolve this problem.
I have applied for the update, and we will fulfill it in 24 hours, please upgrade the firmware tomorrow.
Hi @mlamla, Thank you for getting back to us so quickly.
@BLUETTI_CARE Thanks! Looking forward to giving it a try.
@BLUETTI_CARE , I am having this same issue. Could you please push the update to EB3A2238002347477
Hi @Hatrickn, Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
It’s been a week and looking good so far :slight_smile:
Before, it would get the error and stop working anywhere from 3 or 4 times a day to every day or two. Since doing the update, it has stayed online with no issues (knock on wood).
Hi @rgb, Thank you for letting us know.
I am glad to hear that. :)
Please feel free to contact us if you need more help.
Hello @BLUETTI_CARE - I have the same issue, overload during UPS passthrough with minimal load (48w) or when plugged into AC with no load attached.
Could you please push the update to EB3A2326000725048
ARM V2062.03
DSP V2056.13
Hi @NM_Ben, Now I have applied to upgrade your firmware.
Hi could you please initiate the firmware update again. I checked but there was no firmware available for my device.
Hi @mlamla, I apologize for the inconvenience. After consulting the engineers again, they informed me that your firmware is already up to date, so a new firmware update cannot be pushed. We recommend contacting customer service to arrange for repairs.
thanks for the prompt reply. This is, however, super disappointing. This unit is out of warranty. As said, it was unpacked, charged and then stored away to be used as a back-up, it ultimate purpose. Which it failed recently.
Hi @mlamla, I am sorry for the inconvenience.
We’d like to know how long this EB3A has been stored. Regular use is the best way to maintain the battery—at a minimum, it should be charged once every three months.
Since this unit is out of warranty, would you be open to paid repair services? If so, please send us a message with your order number and other relevant details so we can arrange further assistance.
I wanted to post an update on my EBA3 unit since the modified firmware update from Bluetti. Since this update has been pushed to my unit about 3 months ago; it has been working almost perfectly. I did have one incident where it was plugged in and charged at 100%, I disconnected power, and tried to run a device on battery. When I turned the inverter on, it said battery was a 0% and froze up. I reconnected it to power, it charged back up, and started working normally again. Since this issue; it has been working flawlessly. No more overload messages, or other issues. I don’t use this a lot; it mostly sits charging waiting for a power outage. My only complaint now about this unit is the fan which has been noisy since day one, but it’s still works, and doesn’t bother me bad enough to do anything about it.
Thanks Buetti for fixing this issue!
Yes the overload fixed , but the fan controller still buzz like hell making this unit not recommendable for new users.
I’m having the same overload issue when using as an ups. Any updates to this issue?
S/n: EB3А2338004511470
ARM v2057.11
DSP v2056.14
