Hello, I have tow Bluetti eb3a.
I have charged them with AC over night. in the next morning (after 8h) they ware Hot even tough charging had finished hours ago.
They ware apparently off, i turned on the display and it showed 000W in 100% cahre 000W out.
Exactly waht you would expect…
BUT they consumed About 54W input power event tough they append to be off and showed 0W input power.
i confirmed this by plugin one eb3a AC input in the other eb3a AC output
@lambda The inverter of the EB3A being charged is started and has reached 100% charge, which is not actually charged. The input displayed on the EB3A screen refers to the charging power , therefore displayed as 0 W. The output of the other EB3A shows the apparent power (in this case, because the active power is 0 W, it is equivalent to the displayed reactive power), although there is display power, but it does not actually consume.
What dose this mean?
“The inverter of the EB3A being charged is started and has reached 100% charge, which is not actually charged.”
Pleases try to say it differently because i can’t understand.
“although there is display power, but it does not actually consume.”
I think we have a misunderstanding.
The EB3A is actually consuming real power. (its getting hot) its not only reactive power.
Its real power and heat is produced. the heat is coming from real power.
